Audi style 4th gen headlights
Old Dec 2, 2008 | 11:00 PM
  #161
Cdg2125's Avatar
ok so the idea is that the parking and the brake lights will go through the pwm and the 12v reg. The vreg will output the higher voltage. I have a diagram around here I'll post up. Just gotta find it.
Old Dec 2, 2008 | 11:10 PM
  #162
Cdg2125's Avatar
Ok so here is the diagram:
you can see how the parking and brakes get wired and basically the brakes will override the pwm when applied. This is the setup I'm using for my new tail project.
Old Dec 3, 2008 | 10:02 AM
  #163
darklegend06's Avatar
This diagram is slightly different from what I was planning do.
Old Dec 3, 2008 | 10:20 AM
  #164
Cdg2125's Avatar
thats fine. Just that diagram is a good way to wire it. There are other ways. You just need to make sure that the setup is ok for the type of array you have. What was your plan?
Old Dec 3, 2008 | 09:39 PM
  #165
The diagram used a sharp regulator, I was going to use a 12v regulator from radio shack.
Image taken from HID planet
Old Dec 4, 2008 | 09:01 AM
  #166
Cdg2125's Avatar
yeah that route would work too. Just that the sharp vregs are better than the lm317s you'd get at radioshack. Your diagram will work fine tho because it's the same concept. The parking lights run through the pwm and the lm317 and the brakes run to the lm317 on the pwm and change the output when the brakes are pressed. Just with mine it basically bypasses the lm317 on the pwm and uses the sharp to regulate the differences.
forget to ask, is that pwm sketch modified? Is that using the npn setup or switched to pnp setup?
Old Dec 4, 2008 | 09:39 AM
  #167
If I read everything correctly, I'm using the one that came with the PWM kit, which is the NPN.
Old Dec 4, 2008 | 09:51 AM
  #168
Cdg2125's Avatar
ok. If you're on hidplanet take a look in the advanced sticky thread. There is something in there about changing it to a pnp. It's better for cars because the npn uses ground connection instead of power connection. With cars you're using 12v signal to power the leds, having the npn transistor is not the best idea. Here's the link to the thread: http://www.hidplanet.com/forums/viewtopic.php?t=27245
Old Dec 4, 2008 | 10:34 AM
  #169
Yeah I read about that. Then I thought it was too much work to do.
So I was planning on doing the diagram I posted couple posts above.
Are you changing yours to PNP?
but if I was going to do the PNP transistor route, how would the schematics change?
Old Dec 4, 2008 | 10:43 AM
  #170
Cdg2125's Avatar
no i'm not changing it because the way I'm doing it takes the output from the 555 timer to the sharp. Don't even need the lm317 on the pwm for my application. If you're going to use the pwm from quikar I recommend modifying it to the pnp transistor. Its a safer bet for your car.
Old Dec 4, 2008 | 10:59 AM
  #171
I'll consider what you said, so I'm going to think of how to wire these things up now. Also write a list of what I need.
Old Dec 4, 2008 | 01:09 PM
  #172
Cdg2125's Avatar
what do you mean how to wire them up? The led arrays?
Old Dec 4, 2008 | 08:32 PM
  #173
No the schematic of the board to the LED arrays.
Old Dec 8, 2008 | 12:40 PM
  #174
reese4's Avatar
im looking 4 some angel eyes 4 a 95 maxima.
Old Dec 8, 2008 | 12:43 PM
  #175
reese4's Avatar
Old Dec 8, 2008 | 01:38 PM
  #176
Coolsaber57's Avatar
Noober alert.
Old Dec 8, 2008 | 05:55 PM
  #177
Flava_24/7's Avatar
Boosted Panda
You will have to make them, no one sells them for the max..
http://www.geocities.com/jvxdriver/eagle_eyes.htm
But even if you do make them, how are you going to attach them? There also going to look extremly retarded in halogen housing with a halogen bulb shooting through them.
Old Feb 19, 2009 | 10:14 AM
  #178
kkozy1982's Avatar
Little Asian
what happened to all the pictures?
Old Feb 19, 2009 | 11:18 AM
  #179
I don't know what you are talking about, but they should all be visible. I haven't taken them off of my photobucket account. If not it's on my hard drive at home (I think).
Old Feb 19, 2009 | 02:11 PM
  #180
00MaxSE's Avatar
Pointy Elbows
I can see them
Old Mar 10, 2010 | 11:20 PM
  #181
going a different route.
Does anyone know how the key system works with the locking of the steering wheel? Thanks.
Just an update for some of those that knew that I finished my tail lights.
Old Mar 11, 2010 | 12:33 AM
  #182
aackshun's Avatar
Where did you acquire your PWM? That's the only thing stopping me from LED tails right now...
Old Mar 11, 2010 | 07:56 AM
  #183
1992maximase30's Avatar
to be honest with you, i hated the audi set-up. they looked ugly and weird.
but you guys came along and did a similar set-up and made it look nice.
Old Mar 11, 2010 | 11:33 AM
  #184
SiathLinux's Avatar
I totally love the look of this, so I'm torn now, cause I want the Skyline style rears, but this looks so good...
Meh, I'll just have to get another Maxima (99 of course) and have one this way and one with Skylines..
Old Mar 11, 2010 | 11:42 AM
  #185
Here is your PWM, I got it from here. Also known as a dc motor speed controller http://www.bakatronics.com/shop/item.aspx?itemid=383
Old Mar 11, 2010 | 11:43 AM
  #186
funny thing is. I drove around with those skyline LED rears while I worked on these tail lights. I wouldn't get the skyline LED rears because they are made really cheap.
Old Mar 11, 2010 | 11:44 AM
  #187
Thanks, but I still want to fix these up. When I have time and the extra money to do this I will redo this.
Old Mar 11, 2010 | 07:17 PM
  #188
J_wright's Avatar
Angel eyes?
Does anyone know where i can find halo or angel eye headlights for a 96 nissan maxima? I have been looking online but have not found any yet. Anything would be appreciated
Old Apr 22, 2010 | 01:24 PM
  #189
adam kwiecinski's Avatar
you have to bAke the houseing 4 those?
Old Apr 22, 2010 | 04:05 PM
  #190
max_dreamer's Avatar
i dont mean to jack the thread, and i know its a couple weeks late. but i just wanted to say i loved my skyline rears on my white 97! made that rear end!
Old Apr 23, 2010 | 03:55 PM
  #191
MaximaZX's Avatar
Interesting...
Old Apr 23, 2010 | 10:48 PM
  #192
very interesting topic its on now.
nothing new with me, except for a leaking trunk. Stupid spoiler!!!
Old Apr 24, 2010 | 02:32 AM
  #193
did you try n remove it? or is it just getten worn out at the mounting holes? thats pretty crappy either way. musta leaked bad if you could tell. i figured that lining on the inside would hide most of it!
Old May 4, 2010 | 02:15 PM
  #194
95Maxed's Avatar
Those lights are pretty awesome. I love audi's head lights.
Old May 5, 2010 | 07:55 AM
  #195
StillMaticc's Avatar
those look good
Old May 22, 2010 | 02:06 PM
  #196
4G-riken's Avatar
ive done this but they run thru the top part on my max. and my 98 mazda protege but my strips have 1 led evry 1 cm, used wether striping inside under the strip just to act like a dam and hold the epoxy and then black epoxy resin behind for that isolated from the headlight real audi look looks grate on both cars
just make shure not to get any resin infront of one of the leds and that the weather seal is stuck on there good or the resin will leak out of it oviously its no prob when its dry
Old May 26, 2010 | 04:17 PM
  #197
El_BoriMax's Avatar
Not bad good job on the project of yours.
Old May 26, 2010 | 06:54 PM
  #198
ABlackSER's Avatar
Looks Nice, must be the new fad I see alot of people doing this to their head lights now.
Old May 27, 2010 | 05:11 PM
  #199
I got sick of mine already, might go and buy some r34 head lights and retro those instead.... what do you guys think?
Old May 27, 2010 | 05:34 PM
  #200
MaxiNone's Avatar
man i want to do this to my tail lights, but too intimidated to try
eeewwwww, why would you buy those ugly tail lights?....
