95 Max need help with Vafc
Well i look at the write up followed it step by step and well idk. i got the Grey wire from the vafc to pin#23 and on the vafc its showing 100% the whole time and i spliced the MaF pin #54 to the vafc with the Yellow being closer to the ecu and it was like i didnt have no maf i coudnt rev past 2500rpms
Heres my layout:
Vafc1 ECU
Blue Pin # 50
ReD Pin # 67
Orange Pin # 67
White (closer to the ECU) Pin # 54
Yellow (closer to the ECU) Pin # 54
Grey Pin # 23
Green TAM Screw on the back of the cluster
Black Pin # 55
Brown (closer to the ECU) Pin # 55
I have the settings on 6cylinder tith the thr. going up
Heres my layout:
Vafc1 ECU
Blue Pin # 50
ReD Pin # 67
Orange Pin # 67
Grey Pin # 23
Black Pin # 55
why didnt you do the green wire to the tachometer pin (#5) on the ecu since thats where all the other wires are?
You have your Maf connected wrongly. The Maf signal is hijacked. The white wire connects to the maf sensor signal and then the yellow wire is connected to pin 54. So you have to cut the original Maf wire.
Look at this pic (courtesy of vqpower)
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
maxima297
09-30-2015 03:32 PM
