Will these Axis Hiro Rims fit on a 4th gen?
Old Oct 5, 2008 | 09:10 AM
sublimeskunk's Avatar
# Style: Super Hiro
# Staggered
# Diameter: 19"
# Width: 8.5" front 9.5" Rear
# Bolt Pattern: 5 x 114.3
# Offset: +20 front +25 Rear
# (1.25" lip front 2.25" lip Rear)
# Weight: 27.0 lbs each
# Color: Matte black with red stripe ( Matt black, or other stripe colors available)
Would i need spacers or modify the lugs?
http://cgi.ebay.com/ebaymotors/19-AX...mZ270281834100
Old Oct 5, 2008 | 09:15 AM
or even these motegis?
http://cgi.ebay.com/ebaymotors/18-BL...mZ200258329886
Size = 18x9" Bolt Pattern = 5x4.5 Offset = +25mm
Old Oct 5, 2008 | 10:04 AM
loud3's Avatar
You'd have poke up front on both of those.
Rear on the motegi would be fairly aggressive, but do-able.
Both of them are going to stick out of your fenders by a fair bit, I would think twice before going with them if you're dropped, or planning on dropping.
Just for reference, I run 20x8.5" +35 offset up front (and it's flush with the fender), and 20x9.5" +40 offset in the rear, and it's flush as well. I would look for higher offsets, unless you're looking for an aggressive 'poke' situatuion.
No spacers would be necessary, and tuner lugs are probably going to be necessary.
Old Oct 5, 2008 | 10:24 AM
BLACKonBLACK98's Avatar
Former Vendor
first off, you need to help yourself. wheel sizing is very easy to understand if you just put in the slightest amount of effort. search would have returned hundreds of threads on this exact same subject. a little simple math (addition, subtraction, division) is all you need.
second, all those will poke, but people seem to forget we're talking mm here. 10-15mm of poke may sound like a lot, but in reality you're talking half an inch more or less. camber, drop, fender mods, etc. are all variables that will change fitment as well.
finally, tying in to both previous statements, "fit" is very open to interpretation. if you ask me stock wheels don't "fit", ask someone else and they might say anything more than a 7" +40 doesn't.
Old Oct 5, 2008 | 10:41 AM
loud3's Avatar
Mine don't fit
I'll elaborate on offsets a little bit, as well.
offset is basically the +/- in MM from the TRUE CENTER of the wheel.
So, a +40 offset is +40mm away from the true center of the wheel. This means the mounting point is +40mm towards the 'face' of the wheel, or outside.
A -15mm offset is 15mm INSIDE the true center.
+/- 0 offset is a mounting point directly in the center of the wheel.
Old Oct 5, 2008 | 11:30 AM
z32drifter's Avatar
The fronts will look about like this... with out camber or fender mods.
Old Oct 5, 2008 | 05:43 PM
QNO_A32's Avatar
stevesmax
Dec 17, 2020 11:57 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 23, 2015 06:18 AM
wyobbagy
Aug 15, 2015 02:28 PM
