Trouble Starting - Cranks Slowly
Old Oct 9, 2008 | 12:42 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
My Max sometimes hesitates when starting. I am always able to get it started, but sometimes it takes several seconds of cranking.
The best way to demonstrate is with a video I took.
http://www.youtube.com/watch?v=9PPVHXZNx2k
If anyone knows how to fix this, please let me know.
Old Oct 9, 2008 | 01:07 PM
pmohr's Avatar
No more Maximas...
Need a few ground wires, more than likely. Had any trans work done recently?
Try running a ground wire directly to the starter from the negative battery terminal.
Old Oct 9, 2008 | 01:11 PM
Dan's Avatar
Dan
It started about 18 months ago when I had a used engine put in. It's been usually intermittent (25% of the time), but lately it's been happening more like 50% of the time.
Old Oct 9, 2008 | 04:16 PM
n_csmith's Avatar
+1 i agree run a new ground from the battery to the starter and see what happens
Old Oct 9, 2008 | 09:28 PM
DennisMik's Avatar
my 97 used to crank slow and i thouht that the battery was dying. I found out it wasn't the battery when it finally wouldn't crank one day. The starter is the wimpyest thing I've ever seen! It has a planetary gear set that the lubrication dries up in and the internal friction is too much for the tiny motor.
I took my starter to auto zone and they put it on their "great" tester and said it was good. Their junk tester doesn't even put a load on the starter, they put 12 volts to it and measure current draw. The starter was so noisy as it spun with no load. I found a thread that said to take apart the planetary gear set and lube it, so I did and was at least able to start the car and get it home. I still replaced the starter because the starter was still not cranking properly.
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
conansriver
Sep 11, 2015 10:26 AM
markevans999
Sep 10, 2015 04:29 PM
