heated seats question
Old Oct 12, 2008 | 08:35 AM
maxfever1987's Avatar
i recently bought a leather interior for my 96gxe , i dunno wat year the leather came from but it works fine in my car, now my problem is that how can i get the heated seats part to turn on for winter, theres a plug underneath for power to the heated element but when i saw the actually wiring from a 96 gle the heated seat harness feeds under the center console to the main harness is there anyway for me to turn the heat on? i bought the switches and wire harness from a org. member already how do i wire it up?
Old Oct 12, 2008 | 09:05 AM
internetautomar's Avatar
mod or sell?
grab an FSM and follow the wiring,
it should not be hard.
Old Oct 12, 2008 | 09:06 AM
xkazik's Avatar
http://forums.maxima.org/4th-generat...t-install.html
Old Oct 12, 2008 | 05:06 PM
heates seat question
hey thanks guy those sticky are really really helpful and i got lil confused so i contacted the wizard but thanks alot again
Old Oct 13, 2008 | 02:40 PM
rrookie5's Avatar
hey, i have a 95 SE and it has cloth heated seats... to be honest i have turned them on but have not been able to tell if its actually heating or not haha, is there anyway to check like with a ohm reader or something? im really not sure obviously..
Old Oct 13, 2008 | 03:44 PM
okie so i have the 2 switches for the seats and the harness along with them, now there are 3 wires black, yellow and white. black is obviously ground so now where (im really not to good with this stuff sorry) now im going to buy the add a circuit thingy tomorrow wat do i do with the yellow and white wires? where do i connect those thankx
Old Oct 13, 2008 | 03:51 PM
Did you see these threads as well??
need help wiring heated seats...
HOW TO: ADD HEATED SEATS & Interior Overhaul
and this?
Make sense now??
Old Oct 13, 2008 | 03:52 PM
After everything was said and done, did you ever get the heated seats up and running xkazik??
Old Oct 13, 2008 | 04:15 PM
no i havent attempted it yet but i will get back to u when i do
Old Oct 13, 2008 | 04:18 PM
and this?
Make sense now??
i tried to understand this but im sorry i im not to do good with wiring diagrams at all if u can tell me where to connect the white and yellow wires would be great i know u pull out the mirrors fuse put the add a fuse in its spot where to next im sorry im causing a hassle
Old Oct 13, 2008 | 04:29 PM
I have a feeling your seats have side airbags. Do they? I say this because there are no white or yellow wires that are part of the heated seats system. Yellow usually signifies airbag.
Can you post up pics of exactly what parts you have?
Old Oct 13, 2008 | 04:32 PM
i dont have airbags in my seat but i will post pics as soon as i can
wat color wires do u have under ur seat for the heat element
Old Oct 13, 2008 | 04:47 PM
underneath my seat i have 2 plugs one plug is for electric movement up down and that stuff i got that part, the second plug has 3 wires yellow, black, white now the harness for the heated seat switch i believe has black, black with white, and just white
Old Oct 13, 2008 | 05:12 PM
hey Wizard just looked at this link http://forums.maxima.org/4th-generat...t-install.html
and the harness i have is the same one like u have for the heated seat switches. now wat r those 3 coming from under ur carpet and y r the 2 white wires connected from each harness? i really thank all for helping me through this (just dont hate me at end)
Old Oct 13, 2008 | 05:39 PM
The 3 wires see coming from under my carpet connect the harness from the seat to the heated seat switch.
The white wires can share the same power source, hence why they are merged into one. Just like the FSM pic.
Old Oct 15, 2008 | 12:45 PM
Hey Wizard, i recieved my harness and switches all in one piece today in the mail the is all connected, no cut wires or anything from the heated seat switch all the way down to the plug thats go into the seat. I called the dealer and they said its probably cuz the leather i have is from a 99 which is the reason i have yellow black and white wire coming from my seat. i checked the plug and it pluged into my seat as well. i have the harness plugged under my seat and the other end has the switches plugged in as well. i went to autozne and they dont carry ADD a circiut thing anymore. So plz can u guide me from here, i dont have 3 wires coming from under my seat like u have and can i plug the wires into the connector that has has power all the tme. Thank you so much i really appreciate it
Old Oct 15, 2008 | 12:55 PM
Infowire's Avatar
I been without heated seats for so long now i think mine are broken i could never get them to work... i wired everything according to the diagram... Hope you can get yours to work! I want to see some results maybe i will attempt to get mine to work.. something tells me its going to be a cold winter.
Old Oct 19, 2008 | 03:59 PM
i just finished wiring up everything and i am getting no power to the seats wat i mean is that the switches are not lighting up meaning no power so i coneecyed the whit wire to the acc mirrors and nothing helped is there a chance maybe there too much ground or not enough power anyone know wat i can do
thanks
Old Oct 19, 2008 | 07:59 PM
mod or sell?
thanks
did you make sure all the relays,fuses, and circuit breakers are functional and in place?
Old Oct 19, 2008 | 08:05 PM
xkazik's Avatar
nope, never got them running , i think i will try again over this weekend tho . i mean i really dont know whats going on . both of the lights on the switches work but no heat
Old Oct 20, 2008 | 12:35 PM
xkazik's Avatar
nvm , about the post above .. i got a chance to try today and i got to connect the seats both work but my passanger switch burned out i think because i tried on the other switch and it work =)) Tank you Wizard =)
Old Oct 20, 2008 | 06:41 PM
um.... i didnt use any relays all i did was tap the white wire into the acc mirrors and the black wires i grounded is there something i didnt hook up cuz even the light on my switches didnt light up thanks
Old Oct 22, 2008 | 11:30 AM
i finally got that thing called add a circuit and my seats finally work the switches dont light up but my rear end does warm up well and THANKS TO ALL FOR HELPING ME speaciallly Xkhazik and Wizard
Old Oct 22, 2008 | 11:44 AM
Glad you figured it out and were able to find the 'add a circuit' gizmo.
It's pretty common for the switches to stop lighting up but still function otherwise.
Old Oct 22, 2008 | 11:50 AM
hey Wizard my personal thanks to u man thanks so much
Old Jan 14, 2009 | 06:35 AM
groundbroken's Avatar
Sorry in advance for my ignorance...I am a newB to the forum. I have a 99 GLE with leather interior and would like the seats to be heated...atleast the driver seat. Any suggestions as to what I need and how to get started? Is it possible that the heating equipment is there but not hooked up?
Old Jan 14, 2009 | 09:41 AM
Welcome to the org! Read this thread and all the links within, and you'll be good to go. The heating equipment is not there, you have to add it.
Your two choices are:
1)swap your seats with heated seats, wire it up per this thread and links provided.
2) Get an aftermarket kit, take your seats apart and install it, wire it up.
Old Jan 14, 2009 | 10:48 AM
Any suggestions where I could find the heated seats or an aftermarket kit?
Old Jan 14, 2009 | 10:52 AM
Maxima_Joe's Avatar
4th Gen Parts King
http://forums.maxima.org/4th-generat...0-shipped.html
Old Jan 14, 2009 | 10:57 AM
Heated seats pop up from time to time in the classified section. As for aftermarket
There you go. Now just track down the seats.
Old Jan 14, 2009 | 06:06 PM
i remember startiing this tread a while ago, and every question u might have and any possible info u need this is the thread that has links provided to other threads and the Wizard and Xkazik came through with alot of help, u should be able to do it urself once u read here.
GregL65
Jan 17, 2020 08:01 PM
captchaos
Mar 15, 2016 12:18 PM
GregL65
Sep 5, 2015 09:37 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
