Throttle Cable..
Old Nov 11, 2001 | 04:43 PM
maximumsportZ's Avatar
Lives in a 350Z
Throttle Cable..
I just adjusted my throttle cables because they seemed slack.. now at a warm idle, the RPM hits 1200... Is that ok? or is it going to hurt the engine??.. I do like how it sounds with the Greddy then before..but if this is bad I will just back it off..
Thanks,
Old Nov 11, 2001 | 04:52 PM
emax02's Avatar
Re: Throttle Cable..
Thanks,
You over tightened your Throttle cable(s). The key is to get the cabel just tight enough so it will not open the butterfly on your thrttle body. IMO you should keep your idle at factory specs.
Old Nov 11, 2001 | 05:50 PM
Lives in a 350Z
well,
whats factory idle RPM? that would be much easier to tell when its just right.
Old Nov 11, 2001 | 05:53 PM
spiff56747's Avatar
I think its like 700 rpms, without AC on... Do a search to be sure...
Old Nov 11, 2001 | 06:40 PM
Wizeguy's Avatar
I don't understand why everyone is tightening there cables. There is suppose to be slack in it! Now too much slack 'could' be a problem. What I would do is open the hood with the car off and have someone push the gas pedal to the floor, you should hear a 'clink', as the butterfly valve opens all the way up. If you from there tighten it all your doing is streching the cable when you floor it. This 'mod' is way over rated and really not needed. A check should be called for that's all.
Old Nov 11, 2001 | 06:48 PM
phatmax95's Avatar
its easier to peelout now that i tightened mine
on a side note-
me and my friend were messing around one time and we tightened his and we got it to idle at like 2500 and were riding down the street at idle, and it was shifting gears.. it was funny
Old Nov 11, 2001 | 07:46 PM
Stillen_I30's Avatar
the cable should not have enough slack that it sticks out of the metal crescent shaped loop. it should be just tight enuf that it remains inside it...so that when your foot hits the gas, there is no "play" before the car actually moves. Factory idle is adjusted at between 650-700rpm on an automatic with teh car in neutral (not park for some reason) and all accessories off.
Old Nov 12, 2001 | 03:41 AM
TurDz's Avatar
i think i was the one who started this all..sorry. hehe
Ethan (emax95) was the first to post a throttle body cleaning procedure...and I followed it.
Unfortunately, I was winging the deinstalltion of the TB, kinda loosed that TB stop screw, and i kinda messed with the lines too.
But luckily the org got me back on track.
I had idle and acceleration problems for a while..surging and unevenness...could you ever guess what the problem was?
it was my battery...now, it runs sooo nicely and smoothly again. funny how a battery can do so much.
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 16, 2015 12:17 PM
Bonka
Sep 14, 2015 11:18 PM
