MAF Sensor
Old Oct 26, 2008 | 03:46 PM
Pilot8680's Avatar
MAF Sensor
I'll like to know the symptoms of faulty Mass AirFlow Sensor.
My car has 252,000 miles and recently when I decelerates, the rpm drops down to 300 and sometimes the needle fluctuates up and down which cause the car to vibrate. I haven't check for any codes but according to online, MAF might be the culprit. I cleaned the MAF this morning but still has no luck.
How do I check for broken MAF w/o checking for codes? and what else can be the problem?
Old Oct 26, 2008 | 06:38 PM
pmohr's Avatar
No more Maximas...
Why haven't you checked codes? Is there a reason you want to diagnose your problem while specifically ignoring any codes you may have?
That doesn't make any sense. Check the codes, report back.
Old Oct 26, 2008 | 07:08 PM
QNO_A32's Avatar
TPS?,VSS? CEL on?
Old Oct 27, 2008 | 09:17 AM
altezzablazes's Avatar
GET A OBD SCANNER OR TRY ADJUST YOUR IDLE SCREW
Old Oct 27, 2008 | 09:48 AM
Nycist's Avatar
go to autozone, have them read the codes(its free) post up your findings.
if it wouldnt rev. above 2k i would call it maf for sure, right now i can be a couple things.
Old Oct 27, 2008 | 09:54 AM
jd885's Avatar
it sounds like a MAF i would unplug the sensor and see if it runs any different and go to autozone and get those codes pulled
Old Oct 27, 2008 | 12:36 PM
njmaxseltd's Avatar
Clean the TB and the IACV, at 252,000 they are probably pretty gunked up.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
