Shaking Problem
Old Oct 29, 2008 | 06:16 PM
ILLeSt MaX's Avatar
Shaking Problem
Today I had a flat tire on my front passenger side. I put my on my spare and took my flate tire to a local tire shop to have it plugged..
Once I got there, they told me that I needed a new valve stem and they repaired the tire. They even took off the spare and put on my original wheel for me.
Once I got home, I started doing about 40mph, and my steering wheel and my car was shaking horribly. It has NEVER done this before. I plan on taking the car back to the shop tomorrow, but any ideas what could be wrong so I dont look dumb?
Thanks guys
Old Oct 29, 2008 | 07:16 PM
ILLeSt MaX's Avatar
bump
Old Oct 29, 2008 | 07:36 PM
allensteiner21's Avatar
over/under torqued lug nuts, wheel balance off, air pressure different than in other tires, tire damaged from driving/sitting flat.
Old Oct 29, 2008 | 07:37 PM
97SEdriver's Avatar
this place is dead
it sounds like they knocked off the weight that balanced the tire.
check your tires to see if you have weights on all the other rims (it could be on the inside possibly) and then check to see if the one that was just fixed has one on it as well
Old Oct 29, 2008 | 07:44 PM
Spitzberg Beast's Avatar
Either the tire is uneven meaning the tire is damaged or it needs to be balanced.
Old Oct 29, 2008 | 08:12 PM
bamboomerang's Avatar
Running a higher air pressure (especially the maximum) will help you feel every crack in the road. First I would see what they're at, and if they're even, secondly, as suggested, the balancing weight. Try everything people have suggested already before paying for an alignment. . .
Old Oct 29, 2008 | 10:24 PM
Snypa's Avatar
i think the wheel needs balancing.Weight issues there.
Old Oct 29, 2008 | 10:57 PM
96blkonblkse's Avatar
Probably didnt balance it correctly. Sometimes, especially when you use the stick on weights, they fall off, if the surface isnt perfectly clean before sticking them on.
Take it back, have them re-balance it. That or check for a loose wheel, that will usually cause a clunk when taking off though.
Old Oct 30, 2008 | 06:50 AM
ILLeSt MaX's Avatar
thanks for all the help guys.. im about to head over now to check it out
Old Oct 30, 2008 | 07:27 AM
KRRZ350's Avatar
I don't know why people bothered to reply after this, throroughly covers what it could be related to the "incident"
Old Oct 30, 2008 | 09:44 AM
hitm4n666's Avatar
hmmmmmmmmmmm i drove a 99 maxima with 20s it was the worst ride ever
Old Oct 30, 2008 | 10:18 AM
you clicked the wrong thread
Old Oct 30, 2008 | 07:02 PM
maxfever1987's Avatar
its most likely not balanced, and if its an alignment issue u would know by the steering wheel being straight but ur car drifting to the side i would check the pressure and weight for balancing
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
Noela
Sep 26, 2015 08:22 AM
