need help with awful squeal when turning
Old Oct 30, 2008 | 02:54 PM
AceTKK's Avatar
recently my 96 GXE has been squealing a little bit at startup and sometimes when driving. I need to change the belts and possibly the tensioner and have ordered the parts. I noticed the last couple of days that turning the wheel all the way to either side causes the squeal also, even when stopped and regardless of engine rpm. What does this point to? Is my PS pump or rack the real culprit? Has anyone ever identified the same problem and fixed it successfully?
Thx
Old Oct 30, 2008 | 03:27 PM
Konstantin's Avatar
as for the squeal at start up. My 99 used to do that when i first bought it. Turned out to be a bad starter, although I don;t think that should effect your steering.
Old Oct 30, 2008 | 06:03 PM
pmohr's Avatar
No more Maximas...
Thx
Could be the pump seizing up and the belt slipping, how'd your fluid level? I've seen that before due to low (well actually none) fluid level. Or of course it could just be an extremely worn belt there.
Old Oct 30, 2008 | 06:14 PM
bamboomerang's Avatar
my PS pump squeels when the fluid gets too low and I turn the wheels (leaky hose. ARG!), it sounds like a moaning dieing animal.
When exactly does the sound happen? while turning? when firing up? backing out?
Old Oct 31, 2008 | 12:34 PM
AceTKK's Avatar
Thanks for the replies guys. I'm going to check the PS reservoir after work today and see whether that's a contributing factor. I'll follow up with more info then.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
salty318
Sep 29, 2015 01:21 PM
