Lighting/electric problem... tailights and parking lights ****ted out on me today..
Old Nov 11, 2001 | 09:04 PM
NYCe MaXiMa's Avatar
I was at work since 2, just came back some 1.5 hours ago. I was driving back home and got pulled over, turns out my tailights weren't working. Cop was cool though and let me go, just told me to turn on my hazard lights and drive that way in the slower lane. My tailights don't turn on, unless I hit the brakes. Also, I came around the front and saw that my parking lights were ****ed up too and didn't work. It was already dark and I checked the fuse to the tails but it looked fine, although i'm not 100% sure (it was dark). Yesturday I was screwing with my parking lights and tried to fit an amber bulb in just one of them, but ended up putting the stock one back in and they all worked fine. But today the parking/tail lights won't work. Where should I look, I'm a dummy when it comes to electric stuff, the fuse looked ok, what else can cause both the tails and the parking lights to fail at the same time? I know i couldn't blow all bulbs at the same time. It's gotta be the fuse though, right? Also, where is the fuse for the parking lights?
thanks.
Old Nov 11, 2001 | 10:48 PM
BRIGBOY's Avatar
If your guages ever won't light, then neither will the tails.
Ant that is the fuse labeled INT ILL on the inside.
Old Nov 12, 2001 | 02:21 AM
asianpr3082's Avatar
check under your hood where all the fuses are cuz mine happen to me but the cop gave me a ticket.. bastard. anywayz i was mad and told him that he was raciest ... hehe but yeah did u mess with the wiring cuz that's what happen to me when i messed with it
Old Nov 12, 2001 | 10:29 AM
breaux124's Avatar
The fuses for the taillights aren't under the hood. Those fuses are in the fuse panel next to the steering wheel.
You should be able to look at the fuse and see if it's blown, or you could just stick a new one in there to make sure.
Old Nov 13, 2001 | 11:18 AM
ok, i just checked again, my tail light fuse is blown. However, I can't seem to locate the parking light fuse.. anyone have any idea on where it is?
also
(silly question) but where can I buy some replacement fuses? autozone/pepboys and such have them right? (never needed any, but the replacements my dad used for his car are too big).
thanks
Old Nov 13, 2001 | 11:22 AM
Sprint's Avatar
believe it or not.. if your L. Tail Light fuse is out.. your parking lights will not work. replace that fuse and then that should fix your problem.
when you do go to the store to purchase the fuse.. buy the fuse for 1 step higher also.. that way if it keeps blowing you can go one step higher no problems. I have 1 step higher fuse becasue when i rewired my corners the L. Tail Light fuse blew and i had to put a higher fuse in to keep it from constantly blowing..
Yes Autozone, Pepboys should have it.. just grab a fuse that doesn't affect anything and take it in the store with you..
Old Nov 13, 2001 | 11:26 AM
when you do go to the store to purchase the fuse.. buy the fuse for 1 step higher.. that way if it keeps blowing you can go one step higher no problems. I have 1 step higher fuse becasue when i rewired my corners the L. Tail Light fuse blew and i had to put a higher fuse in to keep it from constantly blowing..
wow, thanks Sprint!
I thought I was crazy for thinking they are linked, but I was coming from work and they both seemed to go out simoltaneously. So if the fuse is 7.5, I can go to 10? thanks, i'm off to the store.
Old Nov 13, 2001 | 11:52 AM
Sprint's Avatar
yes..
but i would run the 7.5 again.. and have the 10 handy.. so if the 7.5 blows.. drop the 10 in there.. usually the 7.5 blowing constantly would indicate some form of electrical shortage or over voltage not recommened for the car's electrical system.. lot of people would not recommend you going to 10. They would recommend you investigate futher or have an electricial look at it. Since i futz around with my car electrical system so much and play with wires in my ECU i just dropped in the 10..
Originally posted by NYCe MaXiMa
wow, thanks Sprint!
Old Nov 13, 2001 | 01:47 PM
Toolrocks's Avatar
also
thanks
Your fuse panel usually has some spare fuses in it. Also, get a random assortment of fuses. You'll probably need one again sometime.
Old Nov 13, 2001 | 02:32 PM
thanks guys, I threw a 10 in there and both the tails and the parking lights came on
It actually doesn't blow constantly, I was messing around with the bulbs in the parking lights and that might have caused a short or something, so i blew the fuse. But besides that, it was all good.
Old Nov 13, 2001 | 02:35 PM
I'm sure there are some fuses for your tail light and your corners under the hood i know there are some under the dash too but i ended up changing the one under the hood .... just check it out doesnt hurt to check
Old Nov 13, 2001 | 04:40 PM
Sprint's Avatar
congrats..
Old Nov 13, 2001 | 10:13 PM
Chen127's Avatar
Quick question NYCE Max, do you have an aftermarket cd player in your vehicle?
Old May 31, 2002 | 07:32 AM
Ginuwin3112
hey Sprintmax...same thing happend to me when i rewired my parking lights...turn them on and parking/tail lights do not work..i was wondering where exactly was the fuse for the taillight in the engine bay was?? and the one under the dash? (fuse number)thanx
Old May 31, 2002 | 08:10 AM
ericdwong's Avatar
Did you rewire your corners? The corners and tail lights are all on the same fuse/circuit. BTW, I wrote a little article in the FAQ above regarding the "tail" fuse and corners.
Old May 31, 2002 | 09:16 AM
sil SE's Avatar
sorry had a hard time following, what exactly caused your fuse to blow then?
and on topic but off, can one physically see damage to harnesses and such if youre running a bulb with too high wattage? dont think i am but im paranoid
Old Sep 21, 2011 | 11:04 AM
koolrunnins's Avatar
same issue but different
this kinda weird but my parking lights come on when i hit the my brake, does anyone know what would cause this???? need help badly, ty
Old Sep 21, 2011 | 12:19 PM
Goomz's Avatar
you bumped a 10 year old thread?!?!?!?!!?!??
thats what the noob section is for! and yes i have an answer but not until you post it in the noob section!
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
cruce91
Sep 20, 2015 10:23 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
