gas leak/smell problem
Old Nov 4, 2008 | 01:13 PM
djipka's Avatar
I have this thing and it is annoying. When I bought the car (a year ago) there was gas smell in the cabin every time I used the heater (it was the winter time). I finally found where the gas leak was and replaced the hose. It was one of the short hoses that connects a couple of the pipes. A few months later I started having the gas smell again and I found that it was leaking from the same place again. I tightened the clamp and it was fixed. About a week ago the smell came back. Why does this keep coming back?
Another question I have is about a noise that wasn't there before. It sounds like a loud fuel pump. Its kinda like a very 'thin' whistle sound. Could it be from the vacuum lines that connect to the carbon canister? All of this started when I swapped my ECU to a 95 one (the car is a 96).
Thanks for your comments and help!
Old Nov 4, 2008 | 04:30 PM
PRacing's Avatar
Former Sponsor
Don't think the problem is related to the ECU being replaced..
But your fuel pump shouldn't have to do with the leak/smell.
On the other hand, sounds like your fuel pump may be shot/dying. I had to replace one TWICE on a Maxima before.
Old Nov 4, 2008 | 04:52 PM
Snypa's Avatar
The sound you hear, is it just before starting the engine.?
Old Nov 4, 2008 | 08:30 PM
djipka's Avatar
No, its while its running and it's constantly there at any speed and RPM.
The same hose was leaking so I loosened it and moved the clamp a bit and tightened it again. The smell is gone for now. Why does it do that though?
Old Nov 5, 2008 | 08:31 AM
djipka's Avatar
I tried to listen carefully where the sound is coming from and its some where from the back for sure. It's the pump or some of the evap/vacuum lines that take the vapor back to the canister and tank. Is there a way to check if the pump is going bad?
Old Nov 9, 2008 | 03:57 PM
djipka's Avatar
I am still having the stupid leak guys! I need help!
I moved the clamp last week and tightened it again and this week its leaking again. What should I do? The hose is a year old.
And the sound is starting to annoy when the music is not on in the car.
Old Nov 9, 2008 | 07:19 PM
djipka's Avatar
anyone?
Old Nov 9, 2008 | 10:06 PM
K.Hall's Avatar
change the hose and get clamps u can adjust with ur hand instead of a tool..i
Old Nov 9, 2008 | 11:02 PM
JoeMiller305's Avatar
which hose is it i have that same problem
Old Nov 10, 2008 | 03:19 AM
j2b4osan's Avatar
get a smaller diameter hose, one you really have to push on. Re clamp with a new clamp. You prob got a hose that a little too loose.
Old Nov 10, 2008 | 06:59 AM
Hank96GLE's Avatar
Make sure you have fuel injection rated hoses. Parts store guys may have given you cheap coolant/power steering hoses that can't handle FI pressure or break down when they come in contact with fuel. Also consider getting some good FI hose clamps like the ones here: http://www.autobarn.net/iddifuincl.html
Old Nov 10, 2008 | 08:52 AM
djipka's Avatar
my clamps look like that. how do I find out what kind of hose I have? I will have to replace it for sure.
I thought about getting a smaller diameter hose too.
what should I look for when buying a good fuel line hose?
thanks guys!
Old Nov 10, 2008 | 10:16 AM
Hank96GLE's Avatar
I'd use fuel injection hose that meets SAE 30R9 standards, similar to this one: http://www.midwayautosupply.com/pm-3...mp-pi-502.aspx
I used these thermoid hoses on my old Z when I replaced all the FI hoses and never had a leak.
Old Nov 10, 2008 | 01:43 PM
djipka's Avatar
thanks! I'll look into it.
any suggestions on better clamps?
Old Nov 12, 2008 | 08:24 PM
djipka's Avatar
something I just thought about. What exactly size is the gas hose supposed to be? I think the one I have and am using is 5/16 or something like that
Mar 12, 2020 12:06 AM
Maxxx10
Sep 13, 2015 03:16 PM
slowlifer
Sep 8, 2015 05:53 AM
