vibrations - not the good kind
Old Nov 8, 2008 | 08:30 AM
Crusher47's Avatar
After installing the 17 inch factory rims on my '99, I noticed once I get to around 40 mph, the steering vibrates, not enough to affect driving, but enough to be noticeable.
Do you guys think maybe a weight fell off and one or more tires are no longer balanced or is it something more serious like needing new shocks/struts?
Old Nov 8, 2008 | 08:42 AM
maxfever1987's Avatar
i put 18 inch on mine and never caused an issue most likely balance, tread wear, tires in front should match and/or needs a weight
Old Nov 8, 2008 | 08:50 AM
Nopike's Avatar
Sounds like an issue with the tires or wheels and not a shock or strut problem.
Old Nov 8, 2008 | 09:33 AM
Nissantrix's Avatar
it could be a number of things, but most likely a weight, or tred wear on the outer side of the tire. i had a 91 integra that drove like ****, it vibrated all the time when i stopped or accelerated, i put a set of 18's on it and the thing was like driving on rails! turns out the outer tread was bald on the front tires. but the weight thing could be it as well! small vibrations will happen when a weight falls off. so try getn them rebalanced!
Old Nov 8, 2008 | 10:20 AM
Crusher47's Avatar
Thanks guys, I only mentioned the suspension aspect of it because I also noticed a squeeky sound when I apply the brakes and the front end compresses a little, it sounds almost like when you lay on an old mattress, you know that squeeky sound? Car is almost 10 years old and 156K miles, so I'm sure I'm due for shocks/struts soon.
Thanks again!
Old Nov 8, 2008 | 10:31 AM
talk abt squeaking i have been living with a squeaky front spring for a year i even tried to put grease on it but still there but i drive with my music on so doesnt bother me and i now its not my struts since i have a new suspension
Old Nov 8, 2008 | 10:52 AM
Snypa's Avatar
balancing.
Old Nov 9, 2008 | 05:31 PM
Crusher47's Avatar
Yup, it was a balance issue. Had all 4 tires re-balanced and the vibration problem is gone. Thanks!
Old Nov 9, 2008 | 11:43 PM
nyc96max's Avatar
balance or your wheel is bend.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
