Remote door opener re-programming
Old Nov 12, 2001 | 10:33 AM
white98se
I have 98 se. Had to replace an door opener. got a thread off of usenet
maxima group. Did as it said, reprogrammed the new opener. The other old working opener now doesn't work. I re-programmed it. New one fails.
Any idea what has to be done to program them at the same time. I tried setting them both. When they are ready to program.
thanks
Old Nov 12, 2001 | 10:38 AM
GarthG's Avatar
Re: Remote door opener re-programming
thanks
After you have programmed the first one, unlock the door, don't open it though, and then relock it making sure the key is in the ACC position the entire time. Hit the lock button on the second remote. You can program up to 4 remotes, just make sure to do them all at the same time, unlocking the door and relocking it after each one you program.
Old Nov 12, 2001 | 10:40 AM
gtr_rider's Avatar
192.168.1.1
Additional ID code entry
If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
Push lock button on the additional new remote controller once.
This ID code entry enable state and setting mode remain until the driver's door is opened.
*Courtesy of the Sticky Above*
Old Nov 12, 2001 | 10:41 AM
clee130's Avatar
Door opener... are you talking about the key fob remote?
Check the thread titled "Max FAQs" above. The second link in the first post has directions on how to reprogram the remote.
Old Nov 12, 2001 | 10:43 AM
gtr_rider's Avatar
192.168.1.1
Yup, thats exactly what his refering to
Old Nov 12, 2001 | 11:08 AM
clee130's Avatar
Man ... I gotta respond quicker. I thought I would be the first response....
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
magiconthetire
Oct 26, 2015 09:03 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
