So apparently I have ABS?
So, I have the ABS pump, and I have the ABS sensors on the wheels... Yet the ABS has never worked on this car, in fact I didnt know I had ABS until today when I decided to clean the grease off the ABS pump and realized what it was.
I don't have any lights indicating problems with the ABS system.
So how do I make it work, especially since the ABS light never shines (maybe dead bulb?)
Check the fuses first, but most likely your bulb went out from it being on so long just like my CEL. Go to a parts store and get the bulb. Easy as cake to do. Another way to see if it works is to go to a parking lot when its wet enough to slide and you'll know that way. ABS usually makes a semi loud noise. You'll know. Cheers!
Which fuses/relays are for the ABS system?
06-06-2017 02:01 PM
