Anyone else have uneven head lights?
Old Nov 15, 2008 | 10:31 AM
shadyonedeath's Avatar
My driver headlight does NOT sit flush with the grill/hood because it has to be adjusted to the left so much just to hit the beam patteren directly ahead. I'd say its 1 inch sticking on where it meets the grill.
Sucks really. It was like this with before and after the 9007 mod.
At first i thought the front end might have been in an accident but there is no sigh of any damage except from a what looks to be repainted radiator support bar. Car looks clean, i've been in and out of it and hell, if it WAS in a accident, the body shop did a hell of a job making it clueless.
Old Nov 15, 2008 | 10:35 AM
2muchbass's Avatar
i do but its because of numerous minor accidents
Old Nov 15, 2008 | 11:01 AM
Old Nov 15, 2008 | 11:40 AM
Maxima_Joe's Avatar
4th Gen Parts King
There's a clip that secures the adjustment rod to the the headlight. It looks like it isn't clipped to the headlight anymore.
Nopike's Avatar
Thats the main reason I gave up on the 9004 to 9007 conversion. I have a 98 SE with plastic lens maybe other years have a different housing. Just convert back to the 9004's Go high wattage if you need more light than the silverstars can put out.
http://forums.maxima.org/4th-generat...onversion.html
Old Nov 15, 2008 | 11:51 AM
Nopike's Avatar
I just noticed that you said that the problem was there before the 9007 mod. When I installed the 9007's I had to make extreme adjustment to get them aimed with the 9004s properly aimed my housings sit flush like they should.
Old Nov 15, 2008 | 12:30 PM
Not here. My 9004s were adjusted the same way. The previous owner had it like this with 9004's and it was still adjusted severely. I just tweaked it a little to get them aligned "Perfect".
9004/9007 swap had nothing to do with it.
Ill check that out.
Old Nov 15, 2008 | 02:34 PM
Snypa's Avatar
i think it simply needs aiming. Try turning one of those **** that will have it turn inwards to the grille untile it flushes like the passenger side.
Old Nov 15, 2008 | 03:12 PM
tbergma1's Avatar
Thats one of the things i look for when buying a car. If i saw that, i would of walked away from it.
Old Nov 15, 2008 | 03:27 PM
How it is right now, its aimed perfectly. If its flush with the grill, it will point towards the passenger beam.
Old Nov 15, 2008 | 07:24 PM
trand71's Avatar
My girlfriend has a misaligned headlight, but i think that's mainly due to the doctor. But i really don't mind realigning them at night.
Old Nov 16, 2008 | 02:04 PM
AndrewR2442's Avatar
Why don't you try and find a happy medium b/t the two beams.... ie. aim your driver beam more to the right and your passenger more to the right. Then it won't be nearly as noticeable.
My car has been in a few minor front end impacts so my headlights have a few washers in-between the mounts and the headlights to get them close to factory. Maybe you should just add some washers on your passenger side?
Old Nov 16, 2008 | 03:35 PM
RA030726's Avatar
I'm nutty for Nissans
Its just the way it is. There will always be some misalignment. Many other cars from have adjusters IN the lights, they move the reflector and bulb within the housing. We unfortunately got stuck with some old *** design.
Old Nov 16, 2008 | 06:05 PM
good idea. thanks
Old Jan 10, 2009 | 04:29 PM
Could I simply open up the headlight, bend the adjuster slightly to the left and call it a day?
Was thinking of painting the inside anyway..AE
Old Jan 10, 2009 | 04:59 PM
maxfever1987's Avatar
u can do that or buy a headlight from me lo, but i dont c y bending it wont work just dont bend it to that point it might break on u, but if it does i have headlight s for sale as well.
Old Jan 10, 2009 | 05:11 PM
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
