Fog Light Question
Fog Light Question
I just got a new fog light to replace my broken one. The old foglight didn't work before but the bulb wasn't broken or blown. I did replace the foglight and the bulb with no results. It did have water in it though but what i don't get is the fuse wasn't blown and the relay is fine. The passanger side foglight works but the drivers side doesn't. I'm not quite sure what do next besides trace the wiring and look for exposed or shorted wires. By the way I did do a search I looked through about 7pgs with no luck.
Start with the simple easy things. How sure are you that the bulbs are both still good? Next, check voltage at the harness to the foglight, if no voltage is present, check the nearest fuse block as you go eliminating different points in the electrical system
^^+1
Since you said there was water in the old fog light you might have oxidation build up on the terminals in the gray clip. Try cleaning them with terminal cleaner or scraping them clean, if they are dirty. Then use a little penatrox when finished.
Well I checked the bulb and ground turns out the brand new bulb I got snapped off the filliment right at the base of the inside of the bulb.WTF I replaced it with a new one but it still didn't work I looked at the terminals to see ifthe were corroded but they seem fine. I lost my multimeter, can't find the thing I'll see if I can't find it today to check for resistance and current flow.
"man afta all that i'll just run my 12v wire from the one that's working over to the broken one... case closed.. my patience is toooooo low for all that"
damn i have the same issue just today.
f'in foggy d side isnt working either
running cable through STAT!
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
98nismomax
Aug 13, 2015 12:44 PM
