Oil light flickers at stops (sometimes)
Old Dec 8, 2008 | 04:33 PM
4thGMax's Avatar
Just started happening today. If I come to a complete stop sometimes the rpms drop to 6k and the oil pressure light just kinda flickers. sometimes when I stop the rpms are at 7k and it's fine...any suggestions???
Old Dec 8, 2008 | 04:36 PM
nismology's Avatar
Checked your oil level lately? My guess is that you currently have less than 2 quarts of oil in the motor.
Old Dec 8, 2008 | 04:38 PM
4thGMax's Avatar
Just got it changed last week...hmm, I'll check it out now
Old Dec 8, 2008 | 06:07 PM
FallenOne's Avatar
ha, lemme guess you brought it to some quicky lube.. those kids are idiots. i would never let anyone els echange my oil. we have people come into our shop allll the time, and the **** we find makes me sad. Stripped Oil Plugs, Stripped Filter Threads, They didnt change the oil At All, Wrong Oil For The vehicle.. Quarts low. I Mean Really. QUARTS?..
DIY FTW.
also, check things like your oil pressure sensors seal, (its an O ring on maxima's right? never Looked Myself), your CPS O ring, stuff like that..
Old Dec 8, 2008 | 06:21 PM
vqmaxman's Avatar
The light is flickering because the car Is low on oil. Check and make sure the oil level Is not to severly low because you will turn your rod bearings and then the engine will get damaged then you will feel sorry.
Old Dec 8, 2008 | 06:29 PM
4thGMax's Avatar
I checked and it isnt low
TunerMaxima3000's Avatar
Wow, your car is dropping to 6000rpm at idle? sometimes even to 7000? Didn't even know our cars can go to 7k.
Anyways as said check the level first, I can't believe that you would even come on here and post a question about your oil light without having even checked the freaking oil.
Idiot light is on = check the ******* oil!!!
Old Dec 8, 2008 | 06:32 PM
Greeny's Avatar
¯\(°_o)/¯
poor/bad/broken connection at the oil pressure switch.
Old Dec 8, 2008 | 06:42 PM
vqmaxman's Avatar
1+ this answer.
Old Dec 8, 2008 | 07:58 PM
4thGMax's Avatar
I actually just checked. I had it unplugged yesterday to trace the bad wire for the Crank sensor...seems fine now that I took it off and made sure it was on correctly =0)
Still throwing a code for the knock sensor, I thought it takes some other code to give a KS code???
Old Dec 8, 2008 | 08:05 PM
pmohr's Avatar
No more Maximas...
Not if the knock sensor is faulty, which is the entire point of having fault codes...
Old Dec 8, 2008 | 08:07 PM
4thGMax's Avatar
I'll change that too this weekend. I cant believe how helpful you guys are on this site!
Old Dec 9, 2008 | 06:50 AM
njmaxseltd's Avatar
Check the oil level, if it's OK then change the oil pressure switch, it's known to fail on our car, usually it leaks.
Old Dec 22, 2008 | 05:56 AM
fldash's Avatar
Hey guys, just did CV axles yesterday on my car. It has a pretty bad oil leak, but I keep on top of it by checking and refilling as necessary, not sure yet if it's the pan or something else, but it's about 1qt a month. Anyway, put oil in it this weekend as well.
Today on my way to work, there were no issues initially (other than it was 15 degrees outside), however at a stop light just before my work, the oil light started flickering. When I took off, it stopped. Then I pulled into the parking lot at my work and it started flickering again.
What are the chances knocked the oil pressure switch loose while doing the axles? Where exactly is this switch located on the pan?
Old Dec 22, 2008 | 06:00 AM
pmohr's Avatar
No more Maximas...
Originally Posted by fldash
Hey guys, just did CV axles yesterday on my car. It has a pretty bad oil leak, but I keep on top of it but checking and refilling as necessary, not sure yet if it's the pan or something else, but it's about 1qt a month. Anyway, put oil in it this weekend as well.
Today on my way to work, there were no issues initially (other than it was 15 degrees outside), however at a top light just before my work, the oil light started flickering. When I took off, it stopped. Then I pulled into the parking lot at my work and it started flickering again.
You're right there, so there's a good chance, especially considering the timeline.
Old Dec 22, 2008 | 08:03 AM
Snypa's Avatar
im hoping that he really meant 6-7 hundred!!
Old Dec 22, 2008 | 08:14 AM
pmohr's Avatar
No more Maximas...
My idle is around 11,000 RPM
Old Dec 22, 2008 | 08:57 AM
Sfblues7's Avatar
my oil pressure light came on one time when i first started my car up it was like 20 degrees outside, so i turned the car off cheked the oil, it was fine so i turned the car on and no light. Anyways i went to get a oil change after that. 2 days later the same thing happened but i turned the car off waited a little then turned back on and light was still there, about a min or two later it finally turned off. Oil pressure switch?
Old Dec 22, 2008 | 09:18 AM
fldash's Avatar
Oh.. not good. Maybe I was tired this morning, but I went out at lunch to check my oil and its overfilled. It just at the bend in the dipstick. Not sure how much over that is. Anyway, I started it up and drove it around the parking lot and the light didn't come back on... I have no way of draining oil at work, so my options are drive immediately to oil change place, or drive it home and drain oil there, or leave it...
I guess it depends on how far over the bend is above the H line on the stick... any ideas? What would you do in this situation?
Edit: I know I'm an idiot, it was cold this morning, I checked it, added oil, then didn't check it again as I didn't want to wait 10 minutes in the 15 degree weather... ARGH!
Old Dec 22, 2008 | 10:56 AM
rxm6's Avatar
Just a thought, but couldn't you just replace the oil filter? Wouldn't have the mess of draining the oil pan and it might get rid of the overfill.
Old Dec 23, 2008 | 08:55 AM
97SEdriver's Avatar
this place is dead
the vq dipsticks are pieces of ****.....check it a few more times......you will probably get a different reading every other time
Old Dec 23, 2008 | 12:10 PM
maxfever1987's Avatar
6k or even 7k? ho do even manage to stop with that kind of idle? i am really hoping u have put an extra 0 in ur numbers cuz 600 or 700 is the highest idle a 4th gen should have.
Old Dec 23, 2008 | 12:59 PM
yesipuff's Avatar
what kind of oil did you put in there? maybe its too heavy.
Old Dec 23, 2008 | 10:57 PM
CMax03's Avatar
You could always connect a wet gauge and get a pressure reading. But i would check the electrical connection first, possibly loose.... If not loose, take the wet gauge reading... should be more than 10 psi @ idle, 1995-98 @ 3000 rpm 63-79 psi, 1999@ 2000 rpm 56.6 psi
Cotozic
Jun 28, 2017 08:01 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
