OBX equal length headers
IIRC, I think these are the same ones Tilley had on his N/A 4.5 Gen.
The 5.5 Gen y-pipe is different, but if you use the entire set, it should work fine, just like the way the Cattman and Hotshot headers fit, with their respective y-pipes (I mean the y-pipes that come with the headers, not the Cattman y-pipe sold separately), on VQ30s and VQ35s.
Btw, I was just noticing, is that rear header one with the collector/y-pipe? Or are my eyes playing tricks on me? If so you have no choice but to use the whole set anyway.
i have OBX headers on my car. they don't have the equal ypipe portion, they just come together like a regular ypipe. i will say that the fitment was an issue. i had to modify the flanges because the holes for the studs weren't lined up right. i had to basically have a pipe made to fit to connect the front header with the ypipe because the fitment was over 2" off. also i had the part after the flex pipe redone to have a 2 1/2" pipe put on because they only had 2" pipe on there. so after the headache of putting them on and modifying them i have put bout $500 into them to make them work(that also includes purchasing the headers to begin with). i wouldn't recomend them if you aren't mechanically inclined or dont know someone who can't modify them. just my .02
Looks like they already have a bung on each bank and a bung on the y-pipe. That is more than enough for your primary O2 sensors. I'm not even sure why they have more than two bungs - for a wideband or to give you options? Haha.
I got ya. I should have payed attention better.
*There seems to be more discussion inthe 4th gen section so i'm just copying the post I made in the 5th gen section. *
This will definately flow better than stock for us 5 and 5.5 gen guys. The quality and fitment probably sucks, but we cant really complain becuase it seems like they are trying to give us a decent product. Look how many times they've changed the design and each time was better than before.
Factory style > shorty > long w/ 90 degree collector > long w/ smooth collector > equal length. (or what looks like equal length)
It looks like they are trying. And for that price, its worth a try.
This seems to be a 2 piece design from the pictures. Similar to cattman's gen. 1(?) design. It's gotta be a pain to install.
I'm nutty for Nissans
We wont know til some one tries but they should bolt on a 4th gen. The problem lies in OBX's past quality control. This is their 3rd or 4th design. If you remember the 1st set were shorties, bascially stock manifolds with a y pipe. A member test fit them and they didnt clear the front MM. Strike one. Then they came out with that dreaded "T" collector with slightly longer primaries. They even had more than one flex section because fitment varied. JUNK! Then more recently they had long tube primaries with an unequal Y, the rear header was part of the Y, similar to the newest gen. This Y pipe design is a complete rip off from Stillens original design. There was nothing wrong with it. Stillen redesigned their pipes to fit later model VQ's, the 2 piece Y which fits all 3L's. They used the space available, Hotshots and Cattmans donut bend hangs down somewhat. This bend stays tucked up in. Anyhow it may not be the best design but at least they are trying.
I may have to try these in the near future Honestly, I would pay this much just to have the superior sound. VQ's are capable of sounding soooo good with the right exhaust. Using these headers would be a great way for me to completely eliminate anything dealing with EGR, too.
so it doesnt matter that they are made for the 02-03 maxima?? that sounds like its asking for fitment problems but..what do I know about exhausts fitment anyway Oh and that one piece **** is NOT gonna fly...what if you have to remove the y pipe??? your going to have to remove the whole header, thats ridiculous.
whats wrong with the sharp bend, nismology?
The exhaust system of 5th gens is nearly identical to 4th gens. If it will bolt on to a 5.5 it will bolt on to a 4th gen. But there will be no EGR hookup. Hopefully they fixed the filament problem of their previous version and the small collector pipe.
well thats good to know. Now what is the deal with this one piece rear header...There have been times where I had to pull the y pipe and I dont know how possible that even is with this set up.
if this was a 5" pipe or something with a constant flow maybe, but in this instance not so much.
Well, you could always take it to an exhaust shop after install and have them cut the pipe there and weld on two flanges. Actually, if you made up some sort of a jig you could do it off the car, and probably end up with the same fitment as before.
