Tons of Suspenstion issues! YAY
Old Dec 19, 2008 | 05:00 PM
S1cTech's Avatar
So my car now makes a click when I accelerate in any gear now. I doubt it is the Motor/trani mount but I think it could be the Stab link, or bad spring. I am thinking more a bad/broken spring I doubt the Stab link would move this much even if it was loose or bad under very lite acel.
My steering wheel makes the god most awful squeal. It does this on bumps too. This is the inner Tie-rod. Could be the outer as well. I REALLY REALLY hope it is not the whole rack. I would cry. It also squeals when I hit any bumps. SO it could be a bad spring.
Lets see... Oh and I can hear a clunk at times during the steer which also relates to the tierods. Anyone wanna add anything?
I think there is 2 inner tie rods on this right? obv there is 2 outers.
Old Dec 19, 2008 | 05:06 PM
maxfever1987's Avatar
to test ur tie rods jack ur car up and have some one mover ur tires my hands and put ur hand on each tie rod the one feel vibration in or the one u feel movement in is the one u should replace good luck
Old Dec 19, 2008 | 06:34 PM
QNO_A32's Avatar
yeah 2 outers 2 inners. and you would definatly know a broken spring it would be sagging and slamming all over the place. bring it to a shop.
Old Dec 19, 2008 | 10:38 PM
max ride 41's Avatar
damn dude, get her on a lift and do what these guys are sayin, strut mounts click when you turn generally. springs squeak, and you'd know if one was broken cause car would be sagging or pulling.
Old Dec 20, 2008 | 04:04 AM
j2b4osan's Avatar
The only thing that's gonna "squeal" is a belt. No tierod or spring can squeal. Neither can the rack. The popping while turning the wheel is your strut top mount bering. Spring failing is extremely rare. Check to see that all the belts are tight and that there is enough fluid in the ps res. Stab link can cause a click or clunk on acceleration but if it's a rythmic clicking apon accel it's prob the axle.
Good luck
Old Dec 23, 2008 | 07:34 AM
S1cTech's Avatar
Well it is not like the sound of a belt squeel and I know it is not the PS pump because this can so it with the car off. Basically it is like... ERRRRR kinda sound. lol. It is hard to explain. You move the wheel back and forth it will be like "err" "err"
Old Dec 23, 2008 | 07:39 AM
Kevlo911's Avatar
Kevlo for President
Sounds like the strut mount and bearing
Old Dec 24, 2008 | 04:39 AM
S1cTech's Avatar
Anyway I can check for this without lifting up the car? I don't have my Jack anymore. =[
Old Dec 24, 2008 | 11:59 AM
j2b4osan's Avatar
if while your turning the wheel you hear a clunking or popping or chunking or jerking(any abnormal sound or movement while spinning the steering wheel) and its most likely the strut top bering (strut mount bering).9.8 out of 10 times.
Old Dec 25, 2008 | 05:36 AM
dgeesaman's Avatar
Maintenance Monster
Take it to a good alignment shop for a diagnosis.
Dave
Old Dec 26, 2008 | 03:46 AM
S1cTech's Avatar
Dave
So I gotta pay... Great... heh.
Old Dec 27, 2008 | 12:14 PM
Maximus_95's Avatar
if its the suspension, your best bet it to redo the whole thing..... gl
Old Dec 27, 2008 | 03:06 PM
i agrree ^^^^, do it right the first time. you'll thank yourself later
Old Dec 27, 2008 | 05:21 PM
S1cTech's Avatar
I never dropped the car to be honest. I just drive like Mario Andriette in a sports Sedan. lol. I take corners like I am in a AWD car too. I just can't take a slow corner. It kills me. lol
This could be why I am having problems in a 10 year old car.
Old Dec 27, 2008 | 06:22 PM
KRRZ350's Avatar
Your tranny has been junk for awhile now, and IIRC your clutch was on it's way out also right? I hope I'm not confusing your car with someone else in regards to the tranny. Didn't I point out some transmission problems at the beginning of the year along with the front end problems? A rumble/tick when your foot is off the clutch?
Old Dec 27, 2008 | 07:52 PM
S1cTech's Avatar
lol no Kev, that was not me. haha. I don't have no rumble or tick sounds from my tranni. I do have a input bearing that need replacing soon though. Other then that my Tranni is fine. yes the clutch prob has like 20-30% or so of life on it, I'm guessing.
Old Dec 28, 2008 | 01:26 PM
CMax03's Avatar
Borrow/use your neighbor's or use the one in your trunk to jack up and place it on a jack stand. But anyway...Get out that big pry bar and inspect your front end components for damage or wear, just don't replace all your components as stated by some of our orgers...find the source! The strut mount bearing sounds like it may be worn, check your coil spring isolators, the spring may be contacting the strut perch directly cause this screechhhhhh! Just try to look at your car yourself, unless you've got deep pockets! If you feel more comfortable going to a shop, do so but, make them show you whats worn out! Don't just take their words! The shops used to screw women all the time but today's man is not that far from yesterdays woman...they get screwed just as much! They'll test you out regardless of your gender these days. Wish I was there to help you save your money....Anyway Congrats to the Pats over the Bills 13-0 .
Old Dec 30, 2008 | 09:33 AM
torr's Avatar
Tie rods- removal
anyone removed a tie rod without replacing the steering gear mechanism/rack and pinion ? I have play in the rack ball joint with a torn boot. I think this is contributing to a "clunk" when I hit a bump
Old Dec 30, 2008 | 02:13 PM
Hobhob26's Avatar
good luck bro im having alot of issues myself with my suspension get it right the first time though buddy
Old Dec 30, 2008 | 09:39 PM
CMax03's Avatar
You actually mean the inner tierod ( inside the rack)? There's a tool to change that on the car, you also may wanna pick up the two syles of boot band tool to properly install those bands on the boots. One crimps, the winds up the band then locks it with a tab.
Mar 12, 2020 12:06 AM
dcam0326
Sep 18, 2015 04:52 PM
videomano
Sep 8, 2015 03:28 PM
