Woul a trunk from a 95 fit on a 98 maxima?
Old Dec 22, 2008 | 11:54 AM
enik23's Avatar
so i needed a new trunk i found some guy about an hour away from me that sells it for a 100 bucks and its the same color 2! what do you guys think would it fit?
enik23's Avatar
i just dont wana make the trip there. and plus i mean it should right? all 4 gens pretty much the same
Old Dec 22, 2008 | 11:56 AM
Sure, it will fit. But your tailights will no longer fit right. You'll have to upgrade to the 97-99 tails...
Old Dec 22, 2008 | 12:00 PM
maxfever1987's Avatar
u wont have any problem fiitting the trunk, but the 95 trunk tail lights r totally different u will get the look of a 95-96 maxima instead of a 97-99 so ur best option would be if u have a 98 maxima, get a 97-99 maxima trunk and 97-99 maxima trunks look a hell of a lot beter as well.
Old Dec 22, 2008 | 12:02 PM
he will have to down grade to 95-96 tails, not upgrade...,he will have a 95-96 trunk so he will need those years tails
Old Dec 22, 2008 | 12:03 PM
Your sorta right. He has a '98 and is getting a trunk from a '95. He would actually have to downgrade to the '95-'96 tails, then it would be fine.
enik23's Avatar
can i just put on the tail lights from my 98 maxima on to the 95 maxima trunk all my tail lights are intacts just a huuuge dent in the trunk ( got hit by a truck)
Mr.A32ftw's Avatar
Maybe im reading this wrong, but it seems to me that he is switching his trunk from 98 to 95, therefore he would need to switch and get the 95-96 tails to replace his 97-99 tails
enik23, you do realize there's a difference in styling/appearance between the 95/96's and the 97-99 trunks, right?
Old Dec 22, 2008 | 12:05 PM
Yeah, I read it again. You're right. He'll need some 95-96 tails instead.
Old Dec 22, 2008 | 12:07 PM
Not w/o serious modification.
Old Dec 22, 2008 | 12:08 PM
enik23's Avatar
i was not aware =0
Old Dec 22, 2008 | 12:11 PM
i was not aware =0
The 95-96 trunk has a slight "wave" indention between the tails. Kind of hard to describe. Personally, I like the styling of the 97-99 trunk better.
Old Dec 22, 2008 | 12:13 PM
Mr.A32ftw's Avatar
phone actin up, diddnt realize it was already said
Old Dec 22, 2008 | 02:36 PM
RA030726's Avatar
I'm nutty for Nissans
there has been only 1 person i can think of who installed 97-99 tails on a 95-96 trunk. he cut the tails and the trunk i believe. i think he was from canada, had a green 96 with 97-99 led altezzas. it looked ok.
Old Dec 22, 2008 | 02:42 PM
RA030726's Avatar
http://forums.maxima.org/4th-generat...cs-inside.html
Old Dec 22, 2008 | 02:56 PM
fat_kid's Avatar
if the new trunk had the lights you wouldn't need to change them, just the lights would look silly because the brake and the turn signal lights were switched. as far as i'm aware you can still use the outer lights with a newer or older trunk but not the inners.
Old Dec 22, 2008 | 08:27 PM
max ride 41's Avatar
disagree.....
Old Dec 23, 2008 | 11:43 AM
disagree.....
disagree?? can u tell me wat u disagree on? and if it was asked the majority would prefer 97-99 maxima trunk, but u could have ur own opinion,,
Old Dec 23, 2008 | 11:52 AM
and enik23 u will also need the 97-99 maxima tail lights harness as well, the back part of the 95-96 taillights are different than 97-99 tail lights. the harness of a 95-96 cannot be used for a 97-99,
Old Dec 23, 2008 | 11:44 PM
whiteSE's Avatar
wait, i got the 97-99 trunk laying in my backyard...to use the 97-99 tails i need to rewire my rear lights?
Old Dec 24, 2008 | 06:04 AM
no u dont have to rewire anything all u need to get is the 97-99 harness for the taillights. the harness that comes with a 95-96 is different than the harness used on a 97-99 tallight.
CRizz
41
Jun 7, 2021 05:42 AM
Btheman80
May 1, 2018 04:03 PM
2k11ApexEvo
Mar 30, 2016 06:54 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Finkle
Sep 27, 2015 09:53 PM
