changing spark plugs
so i was working on my car today fixing a leaking power steering hose when i decided to take a quick look to see if i needed new plugs and wires... i wasnt even able to see any of the wires. (it was dark, and had crappy flashlight)..
i know this is a new question, but; where are all the plugs located and how hard is it to get to all of them and change them?
you car does not have spark plug wires.
three spark plugs are under the plastic cover that says NISSAN V6 3000...
the other three are at the back, in between the runners on the intake manifold.
It's not a hard job to do, even if you're new to working on cars it will take at most an hour.
http://forums.maxima.org/4th-generat...e-updated.html
v
http://www.vqpower.com/v2/articles.php?article_id=45
Well, IBpmohr I guess
v
so is it fine for me to go to napa or somewhere to get spark plugs or should i go to a nissan dealership? i saw in another post that Bosch plugs have created issues in the past so ill stay away from those and ive been told to use platinum plugs on more than one occasion.
Just get yourself some NGK coppers, and you're good to go.
And since you need a little help changing plugs - http://www.infinitihelp.com/diy/i/pr...eplacement.htm
Hi guys I was reading and is been said here that there is been issues with Bosh Platinum , well I have used Bosh Platinum since I bought the car brand new in 1994 and never had an issued , so the question is what plugs work best not whats more affordable since the plugs I buy are about $12 each .. so which are the best plugs for a 1995 max 5 speed ???
thanks
thanks
thanks
thanks
You could get some expensive plug for your car, but again, there's really no point. Regular NGK coppers are cheap and they work well. So they only have a ~30k mile life, big deal.
ok .. that sounds fair , so why do the bosh have issues ? in spring i'll try the NGKs .. of the topic what oil you guys use ? I have been using Mobile 1 and a buddy of mine said that i shouldn't used it cuz syntec oil is not safe or good to use on engines that have more than 100.000 miles !! is that true i will search more on this ..
Thanks guys !!
Thanks guys !!
Thanks guys !!
Thanks guys !!
You're buddy's an idiot. But best to ask that ridiculously overasked 'synthetic or dino' question in the forum below, you'll likely get flamed slightly less.
http://forums.maxima.org/fluids-lubricants-52/
Thread's derailed as is, and OP's question has been answered, so might as well ask here. If it's interesting enough to deserve it's own thread, we can go ahead and do that (heh, starting to sound like a mod now).
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
