Heated Steering Wheel
Old Jan 10, 2009 | 10:10 AM
IlyaK's Avatar
The Golden One
Has anyone put a 2002-2003 Maxima/I35 Heated Steering Wheel into a 4th gen? Or perhaps an I35 one?
Would the 4th gen airbag still work/fit?
I'd love to do this. I plan on installing heated mirrors and finding some heated seats (my leather isn't heated) for the car. Would love to complete the setup with a heated wheel.
It would be even better if it was possible to use the buttons for the radio and cruise, however I think the clock spring is just different enough to require a lot of wiring to use those.
Old Jan 10, 2009 | 10:54 AM
pmohr's Avatar
No more Maximas...
Vasiliy did, at one point. Said he didn't use the airbag, though.
Originally Posted by vsamoylov
here are 2 pics of my momo steering wheel that i have on my max. its so much better then the oem unit. i know you guys are going to start to say its pointless and not safe because there is no airbag but i dont care. safety the last thing on my mind. i love it. its smaller then the OEM wheel. actuall size is 13.8. all you need to install it is the wheel itself and the hub. i dont regret buying it. i used to have a 2k2 heated steering wheel from a 2k2 max but i didnt have a airbag for it. the heated feature worked also. so far i know that the steering wheels from 5th and 5.5 gen and altima fit on the max. i dont see why the 350z or g35 wheel wont fit but it will be pricey and hard to find.
well i currently have a 2k sterring wheel on my car with the airbag. everything fits withouta problem. i have a 2k2 sterring hweel in black leather that is heated for sale also witrh the buttom that turns it on. i had this steering wheel on my max but i removed it cause i dont have a airbag for it. if anybody wants it, let me know.
on the airbag though, it is so simple to remove it. when i did mine, i disconected the battery, removed the 2 torx screws that hold the airbag (1 on each side), and disconet the airbag. to remove the torx screws, you have to but the socket with the torx screws. they can be found at any auto store. i got them for $10 at kragen.
Old Jan 10, 2009 | 10:59 AM
IlyaK's Avatar
The Golden One
Haha. My best friend had the setup I want I didn't even know.
I'll have to go talk to him. Thanks PMohr.
Old Jan 10, 2009 | 01:53 PM
Blackwind's Avatar
send me the info when you find out please.
Old Jan 10, 2009 | 02:54 PM
IlyaK's Avatar
The Golden One
Will do.
Old Jan 10, 2009 | 05:15 PM
maxfever1987's Avatar
i did the heated seat upgrade but i dont even know i f we can put heated side view mirrors in there if we want to upgrade maybe i will start a new thread abt it, but if u get ahead of it all the best man keep us updated
Old Jan 10, 2009 | 05:38 PM
IlyaK's Avatar
The Golden One
Heated mirrors should be extremely simple.
Just splice the wire that turns on the heat function to the defroster button in the center console so when you defrost the rear window, the mirrors defrost as well. The rest of it should be plug'n'play as it is the same part (same harness as non-heat mirror).
Old Jan 12, 2009 | 03:58 AM
goldtooth's Avatar
Update this thread if you find any more info on the heated steering wheel. I would definately love this mod- upgrade.
Old Jan 12, 2009 | 06:05 AM
IlyaK's Avatar
The Golden One
I will definitely post what I found out from my friend.
Old Jan 13, 2009 | 06:27 AM
IlyaK's Avatar
The Golden One
Any wheel would work. I both had the 2k wheel and the 2k2.
to hook up the heater on the 2k2 wheel is simple. All you need is the switch for it and all it needs is power and ground to the switch.
airbag wise i never had mine hooked up. I know the clockspring is different and you cant use the 2k2 clockspring unless you decide to use the whole steering column.
if anybody is interested, i have a beige 2k wheel for sale with the airbag. its not heated
Originally Posted by IlyaK
Would the entire steering column work? or would mods be required you think.
the whole column would need to be modified to fit. The part where the shaft meets the rack is a direct bolt on but the brackets are different on the 2 columns closer to the driver.
You could cut and weld the brackets.
anyway is is not a direct swap unless you dont care about the airbag and pull the light.
There it is guys. Doable but not for everyone. Too much work for me personally so looks like I won't be doing it.
Old Jan 13, 2009 | 09:25 AM
goldtooth's Avatar
I agree. Not worth the hassle
Old Jan 13, 2009 | 09:39 AM
nsnrider's Avatar
you can disconnect the cruise control and use those wires in the clockspring for the heater in the steering wheel. That way you won't have to swap the steering columns. The rest is simple, run power to switch, to relay, timer and to the heater via the cruise lines. Not that hard as long as you're familiar with messing around with electronics. G/L for those who decide to do this.
Old Jan 13, 2009 | 09:57 AM
IlyaK's Avatar
The Golden One
That's the problem.
I want to have heat, cruise, and if possible audio controls. But since I won't be able to have cruise at least, it's not worth it. I love my cruise control feature on long trips.
I'll just get heated seats and mirrors and call it a day. Wheel doesn't get THAT cold I guess.
Old Jan 13, 2009 | 10:06 AM
SpooledVQ35's Avatar
Hooking up the wheel so it heats is not the issue.
Hooking up the cruise control is also not a problem. You could always make a remote switch somewhere on the panel to turn it on and off and the rest of the features with it.
The issue for people is the airbag. For some it is a safety issue and for others it is required for inspection.
Best option is to get an aftermarket steering wheel. The stock maxima wheel belongs on a bus not a car IMO....
Old Jan 13, 2009 | 03:46 PM
Blackwind's Avatar
That's the problem.
Ilyak im gonna keep you in the loop on my end of this project. ill pm you with some ideas.
Old Jan 13, 2009 | 04:32 PM
IlyaK's Avatar
The Golden One
Aight.
I want a completely functioning wheel. Meaning, cruise, heat, and audio. If you can get that working with minimal modding...let me know.
Old Jan 13, 2009 | 09:36 PM
FallenOne's Avatar
Subscribed. Id love Heated Steering Wheel, and Audio Controls.
Old Jan 13, 2009 | 11:37 PM
davidforehand's Avatar
http://www.dual-star.com/index2/Ride..._grip_kit1.htm
wheelskins
I use the grip heaters on my motorcycle and works great, I was wearing thin gloves and was comfortable at about 15degrees with no wind protection. Takes about a minute or two to get hot. This would be a cheap/ghetto/easy way to accomplish the heated steering wheel without loosing the airbag.
Old Jan 14, 2009 | 04:35 AM
nalc's Avatar
wheelskins
If you sneak the wires through the back, and use a black leather perforated wheel cover, it would look just like factory.
Old Nov 27, 2011 | 03:30 PM
jvanen's Avatar
Heated steering wheel install
Has anyone been successful at installing a heated steering wheel so far? Hoping to do this mod. Trying to get the parts list together.
Old Nov 27, 2011 | 03:51 PM
tigersharkdude's Avatar
another old thread bumped. Please look at posting dates before bumping threads
Old Nov 27, 2011 | 05:56 PM
MAXiPAD72O's Avatar
omg relax dude^
Old Nov 27, 2011 | 07:43 PM
we've had like 8 super old threads bumped today, one was nearly 12 years old. When there is no reason to bump an old thread, why is it bumped?
Old Nov 28, 2011 | 03:29 AM
adroitcaptor's Avatar
On the other hand, be happy they are searching!
FWIW My father has this on his max. The steering wheel has not held up well. I am not sure if it has anything to do with the fact it is heated. Anyone thinking about doing this mod should research this. Not worth it to have a crappy looking wheel IMO.
Last edited by adroitcaptor; Nov 29, 2011 at 02:13 AM. Reason: changed "help up" to "held up"
Old Nov 28, 2011 | 08:29 AM
MAXiPAD72O's Avatar
i don't ****!ng know lol probably because he didn't wanna start a new thread and thought this thread was the most relevant one he could find about heated steering wheels. stop being a thread monitor it's really no big deal ur just annoying to me that's why i'm saying something lol
Old Nov 28, 2011 | 08:48 AM
Old Nov 28, 2011 | 09:01 AM
MAXiPAD72O's Avatar
god ur lame lmao
captchaos
Mar 15, 2016 12:18 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
