5 speed swap pilot bushing question
Old Jan 10, 2009 | 05:47 PM
euromaxima's Avatar
swap the flywheels and ready to install clutch and align tool wont fit, do i need a pilot bushing or what. thanks for info
BRandon
Old Jan 10, 2009 | 07:39 PM
pmohr's Avatar
No more Maximas...
You don't need a pilot bushing, it isn't used on the FWD VQ trans.
Alignment tool won't fit what, the clutch disc?
Old Jan 10, 2009 | 08:56 PM
MaximaSpd85's Avatar
is this on a dek by any chance? when i recently did a 01 dek swap, i ran into the same issue. theres something different about that engine as compared to our de's when it comes to using the alignment tool. or something related to it being an auto originally (my engine was from an auto) im not sure exactly what and im sure ill hear "they are the same", but i had the same issue.
Old Jan 10, 2009 | 08:58 PM
euromaxima's Avatar
the alaignment tool fits the clutch but not the hole in the crankshaft
Old Jan 10, 2009 | 08:59 PM
pmohr's Avatar
No more Maximas...
Too big, too small, what?
Old Jan 10, 2009 | 09:00 PM
exactly, thats what happened to me. iirc the tool is too small.
Old Jan 10, 2009 | 09:07 PM
pmohr's Avatar
No more Maximas...
Odd. Mine worked perfectly, but I still had the bushing for the torque converter in the end of the crank:
I can definitely see how the alignment tool would just flail around with no bushing in the end of the crank, though.
My suggestion, just eyeball it. That or wrap electrical tape or somethign similar around the end of the alignment tool until it fits snug and straight into the crank.
The alignment tool I used was for a Z33 (I believe, but really it could be from pretty much any Nissan) but that shouldn't make a difference.
Old Jan 10, 2009 | 09:21 PM
lol, do u have a picture for every instance?
u know, after looking at this picture, i dont remember whether it was too small or it didnt fit because of that bushing, dont remember, but i do know i did have to eyeball and get it as straight as possible, as u mentioned.
i see that FS: timing ring is no longer in your sig
Old Jan 10, 2009 | 09:27 PM
pmohr's Avatar
No more Maximas...
You'd be surprised, last I checked I've taken ~8000 some odd pics with my camera, 95% of them Maxima related.
Hell, I'm in a discussion with a guy who needs VLSD and HLSD pics, and I just happen to have high res shots of an HLSD from Merlyn's trans from the perfect angles.
Yea, someone bought it Thursday. I'm probably gonna go troll the yard again soon, see if there's any more 5 speeds.
Old Jan 11, 2009 | 08:27 AM
Kevlo911's Avatar
Kevlo for President
I installed the manual pilot bushing when I did my swap. I did it so it would be easier to install the clutch with the alignment tool.
Old Jan 11, 2009 | 09:04 AM
Nealoc187's Avatar
SLOW
just eyeball it. it's not difficult to get it close enough to work.
you can also make your own alignment tool using a socket of appropriate size and wrapping tape around it.
Old Jan 11, 2009 | 10:31 AM
euromaxima's Avatar
this is what mine looked like, do i need to remove the torque converter bushing and install the pilot bushing, i got one but it looks like i can put it in like it is not removing the auto bushing.
Old Jan 11, 2009 | 11:18 AM
pmohr's Avatar
No more Maximas...
You'd need to remove the torque converter bushing before installing the pilot bushing, but as has been said there's no point. Just eyeball the alignment.
maxima-junky
Oct 21, 2015 05:17 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
ffcbairn
Aug 16, 2015 09:29 PM
Blackwind
Aug 5, 2015 06:35 PM
