Power Problem
Old Jan 11, 2009 | 09:27 AM
Socrates's Avatar
Power Problem
So this is a strange problem that started a while ago and probably has a simple solution.
After getting back from vacation this past summer I found that the battery in my max was dead. So I got it jumped and it seemed fine for a few days. Then it started dying again. So last month I got a new battery - top of the line titanium whatever. I was gone for the past three weeks and now came back to find the brand new battery dead. Not sure what this might be - alternator?? Any ideas?
Mike
Old Jan 11, 2009 | 10:30 AM
SVI30's Avatar
Any after market items such as audio?
Old Jan 11, 2009 | 11:03 AM
Socrates's Avatar
No - nothing aftermarket.
Old Jan 11, 2009 | 11:22 AM
pmohr's Avatar
No more Maximas...
Have you checked for any sort of parasitic drains on the system?
So no aftermarket alarm or anything?
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
Old Jan 11, 2009 | 11:56 AM
Socrates's Avatar
Nope - no alarm. Nothing added at all. I suppose I can pick up an ammeter and try that.
Old Jan 11, 2009 | 01:56 PM
SVI30's Avatar
Best is an inductive probe but it may not go that low of an amperage. Then you don't need to disconnect the battery cables.
Start with those items that are always on and not switched by the key switch. I had a shorted visor light that plagued me in another vehicle.
Old Jan 11, 2009 | 02:57 PM
95max327's Avatar
had the same problem, it was my power antena not shutting off, and over night it was killing the battery, you have a draw somewhere in your electrical, have you noticed any interior lights on or anything not shutting off after the key is out of the ignition doors are shut and or locked
Old Jan 11, 2009 | 03:13 PM
Socrates's Avatar
Yeah it must be something - But I can't see anything on after the car is shut and locked. It's a mystery! How did you determine it was the antenna?
Old Jan 11, 2009 | 03:21 PM
95max327's Avatar
paid a mechanic 50 an hour until he found the problem 400$ later .. so give it a look at.. he cleaned the antenna and sensor or some crap, just try unplugging your antenna after you get it running again and then let the battery charge back up and then park it for a few days and try again see if thats the problem
Old Jan 11, 2009 | 06:02 PM
Nopike's Avatar
Get an ammeter and check current draw, if it is excessive (see parasitic drain thread) start removng fuses. If a circuit such as the antenna is drawing current when you pull the fuse for that circuit the current will drop quite a bit. Of course if you have the car door open when you pull the fuse for the interior lights that will cause current flow to drop also.
lowpost99
Oct 26, 2025 06:53 PM
DJLAX152
May 4, 2021 11:46 AM
markevans999
Sep 10, 2015 04:29 PM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
