Nothing seems to go right...transmission?
I did a search...most of the problems I've been hearing about are not what I am having, so hopefully this will be a brief thread....
'98 Auto SE, 59,400 miles. B&M Tranny cooler, UR UDP are the internal mods. I JUST (Tuesday) changed the tranny fluid/filter, fuel filter. The tranny fluid was CLEAN, very clean!!! They may have actually changed it before that gave me the car at 51,800 miles.
Anyway, the problem occured BEFORE I CHANGED THE FLUID/FILTER. The problem is also intermittant...seems when the car is cold, the noise isn't there. DISCLAIMER: when I shift from reverse/drive, I always ALWAYS come to a complete stop, but who knows what was done for the 1st 50k on the car, right?
The problem: when I shift from drive to park/reverse/whatever when the car is warm, the tranny makes a pretty loud clunking noise that I am almost positive it never made before. However, my old car did that all the time, and it was fine.
I am just curious to know if anyone else has this noise, or if I should get my *** to Nissan ASAP before the original (I have an extended too) warrantee runs out.
Re: Nothing seems to go right...transmission?
do you think I should replace the UDP with stock? No one ever notices I put it on, but then, I never take my car to Nissan unless I HAVE to......
Originally posted by Sarah99GXE
well knowing Nissan, you should probably take the UDP off....they'll have some excuse that this is causing the problem and tell you your warranty is void ....
SuDZ
well, I just talked to the dealership, and they are going to take a look at it on Tuesday. Stock pulley is returning on Monday. If I can't get the stupid thinig off, then I guess I'll risk it, but I had no trouble getting the thing off/on the first time around. They usually don't notice the pulley because it's silver, but I will attempt to put the stock one back on anyway muaha. I dunno though...they can't prove that it caused the tranny problems, plus, when I got the car, the rear main seal was leaking, so...yeah. I am guessing the previous owner of this car was a #$%^&* to the poor thing.
