fuel hoses leaking.....
allright, facing the motor, the little short one to the left of the block, and the dealer also said there's another one leaking too, wont know which one until i pick up car monday. they want 256.00 to fix and said its 2 hours to do. what rubber fuel line could take 2 hours to get to???? they're NOT doing the work, but im curious to know which one takes so much time to get to. i looked it up, cant seem to find one thats that buried. anybody????
yeh, need to know which hoses for sure. $256 sounds really stupid.
just pick up like a yard of fuel line hose at advance and do it yourself.
subscribed for what nissan has to say
if you replace FUEL HOSES yourself, try to find the metric size 7.9mm or 8mm inside diameter for the best fit and less chance of repeat leaks soon. and at that size it's a pita
to do, but not a couple hours unless you do them all. the fight is to get them back on, even w/spray lube. i just replaced the one between the front rail & the regulator. nissan hose lasted a long time, hope the one from gates does also. probably the hardest to do is the one at the bottom of the filter.
The hose I mentioned above can be done without taking apart anything, but it's a little cramped between the timing cover and the UIM. There's also the filter-hard line, hard line-rail, regulator-hard line, and hard line to the back of the car. The last one is quite long IIRC, and will take a bit of time to do. If they're doing any of the fuel lines that feed and return from the rail, they'll have to remove all of the intake tubing, which adds time.
Personally I got rid of that whole vacuum piping/fuel hard line crap, ran a hose straight from the filter to the rail and another hose from the regulator to a coupler that connects to the stock return line.
Well if they're replacing the crossover hose that goes from one rail to the other, they'll likely bill you for removing the UIM and the fuel rails to do it on the bench. Mine actually started leaking a few days ago, now that it's down to single digit temps around here. It stops leaking once it warms up, so I'm just waiting for a warmer day to get around to replacing it.
Don't really have any pics of that, but I'll see if I can't take a few pics when I do my lines within the next few days. I also removed EGR and EVAP, so the entire vacuum gallery there is useless for me; extra complicated crap that's unnecessary.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
HerpDerp1919
09-29-2015 02:02 PM
