lca question......
Old Jan 20, 2009 | 06:54 PM
max ride 41's Avatar
lca question......
question would be, if bushings are torn will the handiling and kick back on take off be loose??? as, i take off from a start and she kinda kicks like a mule a couple of times and sometimes pulls to the right. reason being is that the right side is still together and drivers side is bad. when it was snowing she kept pulling to the right from take off. im replacing them soon so what else should i replace, sway bar links and what else??? thanks>>>>
Old Jan 20, 2009 | 09:21 PM
DennisMik's Avatar
yeah when a lca bushing goes, the car will pull to the side when you accelerate. you may hear clunking sounds going over bumps/potholes. you don't have to replace anything else because of the bushing, but you may want to replace other high mileage things like tie rod ends and sway bar link bushings while you're under there.
kingw323
20
Oct 21, 2015 08:36 AM
maxocar
Aug 21, 2015 12:57 AM
Nealoc187
Oct 17, 2006 03:59 PM
Nealoc187
Aug 20, 2006 02:54 AM
96blkonblkse
May 9, 2006 05:23 PM
