96 Maxima hard to start
Old Jan 25, 2009 | 05:09 PM
myke321's Avatar
http://www.youtube.com/watch?v=6UyR7dtXKZU
Im having trouble starting my max. It takes a long time for it to crank over and start. Has anyone had the same problem? Please see the youtube video to see my problem.
Thanks.
Old Jan 25, 2009 | 05:17 PM
Carrera's Avatar
What codes is it throwing? Check that out first.
Old Jan 25, 2009 | 05:24 PM
JSMax's Avatar
Sold
is that a check engine light that stays on?
When was the last time you changed fuel filter? Spark plugs? Cleaned air filter?
Original starter?
more information required before accurate diagnosis is made.
Old Jan 25, 2009 | 05:27 PM
myke321's Avatar
No Codes- just had a tune up about 6mo ago and a new starter, alternator, and battery about 2.5 yrs ago.
Old Jan 25, 2009 | 05:28 PM
myke321's Avatar
My K&N is kinda dirty. Took it to the shop and they could not find out what is wrong with it.
Old Jan 25, 2009 | 05:29 PM
myke321's Avatar
And my check engin light is not on.
Old Jan 25, 2009 | 05:31 PM
myke321's Avatar
217,000mi
K&N air
Y-pipe
I'm thinking fuel issue. once i start it and it runs on the freeway for while- it will start fine. Just after it sits for a while its hard to start.
Old Jan 26, 2009 | 08:41 AM
97SEdriver's Avatar
this place is dead
Originally Posted by myke321
217,000mi
K&N air
Y-pipe
fuel filter?
aftermarket starter?
Old Jan 26, 2009 | 08:52 AM
maximadudeIIs's Avatar
Did you ever change your fuel filter? What is the voltage on the battery? I once had a battery fail in less than 2 years, so even if the battery is new it may be a problem.
Old Jan 26, 2009 | 09:22 AM
myke321's Avatar
Originally Posted by 97SEdriver
fuel filter?
I'm going to change the fuel filter today, and i believe the starter is an aftermarket.
As for the battery- I think on my way home I'll take to pepboys and have them check the Volts.
The Shop I took my Max too was just a car shop. I think if after changing the fuel filter, check the battery volts and cleaning the K&N, I'm going to to take it to a "specialist" - a shop that only works on Japaneses cars.
Its a freaking pain starting the car after its been sitting for a while.
I'll report back.
Old Jan 26, 2009 | 09:23 AM
ThreePointO's Avatar
hey ive got this same type of problem. Try turning the car on for a sec (dont turn it ove jsut put the key to on), and then start it up. Sometimes if my car sits for a while ive got this same thing so just wait a few seconds before i turn it over and it starts up fine.
Old Jan 26, 2009 | 10:20 AM
s14240sxsilvia's Avatar
Welcome to the club lol. Does anyone know where's the best place to buy a fuel pump is? I think this may be my problem and just wanted to check if you guys recommend any place before I check autozone or pepboys.
Old Jan 26, 2009 | 12:59 PM
i dont have ne idea. i havent cared enough to fix it. its on the list but under; brakes (pads 95% worn on passenger side), struts (completely blown apart and prob dangerous to drive), exhaust (abut 6" off the ground heald up w/ mechanics wire), and every thing else that could be fixed.
Ive got the parts... now all i need it time..
Old Jan 26, 2009 | 01:25 PM
pmohr's Avatar
No more Maximas...
For OEM, Dave B. If you just want a replacement, any auto parts store or throw in a walbro (probably cheaper).
So priming the system for a second before cranking works?
Old Jan 27, 2009 | 06:39 AM
I'm just going to order this one for 50 bucks
http://treperformance.com/i-827-niss...fuel-pump.html
If I turn it the key to On then Off four times it will start much quicker. Otherwise it takes a good 30 secs to a minute of cranking. So I am assuming this is the problem. Sorry to hijack thread TS.
Old Jan 27, 2009 | 06:43 AM
pmohr's Avatar
No more Maximas...
Have you checked fuel pressure up front? You should do some sort of diagnostics before throwing a fuel pump at it. I'd check the regulator, first off.
Old Jan 27, 2009 | 07:17 AM
No I haven't I really should though. I just pulled the trigger on a fuel pump oh well. I just havent had the time nor motivation to get into it.
Old Jan 27, 2009 | 08:12 PM
myke321's Avatar
I tried the turn the key ON before starting thing- did not work.
I had the volts checked on my battery and it was fine.
Taking it to the Import mechcanic this Thursday - Hopefully they can find out whats wrong.
Old Jan 28, 2009 | 08:03 AM
crazy97's Avatar
Thanks.
You have the starter ground problem. You must be a 5spd..
Old Jan 28, 2009 | 08:47 AM
ruckus1027's Avatar
hey crazy97 im in mn too in st thomas univ...
anyways please do tell more of this ground prob...i have a 5spd
Old Jan 28, 2009 | 09:54 AM
pmohr's Avatar
No more Maximas...
The autos will get the same problem.
Old Jan 28, 2009 | 10:01 AM
crazy97's Avatar
Hey there... Our cars tend to develop some nasty starts mostly when the trans has been removed from the car. In order to fix it you have to either remove the transmission and really sand the hell out the mating surfaces or you can go for option B by hooking nice thick copper wires from the starter mounting bolts to a trans bolt/neg batter terminal and or the body somewhere.. I had to make 3 connections from the starter mounting bolts to get decent starts.
Theres a youtube video from someones car just like this one on here in the link below.
http://forums.maxima.org/4th-generat...verything.html
Old Jan 28, 2009 | 05:54 PM
jxkim's Avatar
check out the starter?
seems simple but it might be the answer...
sounds like it except for that weird suction kinda sound
Old Jan 28, 2009 | 07:14 PM
myke321's Avatar
Naw, I'm Automagic. But that Vid sound like my engine.
Old Jan 29, 2009 | 05:31 AM
crazy97's Avatar
I would try it anyway. I hear autos may do it too. Its cheap to do and can cure your problem. Whatever you do, dont hook any wires to the positive cables!! Just the mounting bolts.
Old Jan 29, 2009 | 02:43 PM
omoran2958's Avatar
im having the same problem, but my max does not start in the mornigs when its cold but once the sun comes up it starts. i changed the engine coolent teperature sensor.
Old Jan 31, 2009 | 12:31 PM
myke321's Avatar
I ran grounds to the tarnny and starter from the neg battery using 10g wire- did not fix anything. After putting the new grounds, I am now throwing codes and have a weird idle-1320 and 325 accoring to the odb. Thinking about just dumping the car. It has 2170000mi on it and I don't know if I want to put anymore cash into it.
Old Jan 31, 2009 | 12:36 PM
pmohr's Avatar
No more Maximas...
Not 1320 and 325, P1320 and P0325. Big difference in how you describe codes for the A32.
P0325 is normal, the KS tends to be bad. It won't light the CEL, so you'll usually only find the code when you have another problem. P1320 is an ignition system fault, could be a dead or dying coil.
You shouldn't have an ignition fault just from adding new grounds.
Old Jan 31, 2009 | 12:45 PM
myke321's Avatar
That's what I thought too. I'm gonna remove thr new grounds and see if the fixes the weird idleing and the codes. This is a real bummer. I was hoping the new grounds would help fix the starting issues.
Old Feb 1, 2009 | 05:31 AM
crazy97's Avatar
Bummer...Sorry to hear.
Old Feb 1, 2009 | 07:32 PM
tyler5619's Avatar
congratulations, and beware.
the vultures are lurking, and ready to call dibs on a partout...i can feel it...
dibs on the headlights...and bose unit...and in-dash clock...
lol...
Old Feb 1, 2009 | 11:27 PM
pmohr's Avatar
No more Maximas...
lol...
I've got a clock for sale in the classifieds
Old Feb 2, 2009 | 06:03 PM
myke321's Avatar
FIXED IT!!!!!!
OMG!! What a pain the @$$ this has been - Today I was double checking everything, engine wires, fuel filter, battery, everything. I was checking the fuse panel diagram under the steering wheel against the fuses, and I noticed something I missed - THERE WAS NO FUSE IN THE "ST" SECTION! The 7.5 fuse that should have been there some how was moved in between "ACC" and "IGN" So I took the 7.5 fuse and moved it to "ST" and now my max fires right up!!! I have no idea how that fuse moved.
Thanks for everyone's help.
And for everyone that is having the same starting issue - Go check your fuse and make sure it's not blown or missing or damaged.
02PearlSE
Oct 7, 2015 02:12 AM
Greenmaxspeed
Aug 31, 2015 09:06 PM
Wolvee
Aug 11, 2015 12:24 PM
dauntlessmax
Aug 5, 2015 10:29 AM
Jcof88
Aug 3, 2015 10:43 PM
