Kill Switch Help
Old Jan 26, 2009 | 06:02 PM
tigersharkdude's Avatar
Kill Switch Help
Hey everybody after an incident last night, I am ready to install a kill switch in my car. My question for you is, where would be a good place to put it at and where is the fuel pump wire at? I need it to be hid but still accessible
Old Jan 26, 2009 | 06:09 PM
Flava_24/7's Avatar
Boosted Panda
Why dont you just buy a decent alarm?
Fastest cheapest way would be to just pull the fuel pump fuse and stash that in your ride somewhere.
QNO_A32's Avatar
rear ashtray???
Old Jan 26, 2009 | 06:16 PM
nsnrider's Avatar
I know one guy wired the door lock/unlock button to act as a kill switch. Everything looked stock but if you didn't press the door lock, car wouldn't start. It was hooked up to a starter relay though not the fuel pump. You can always put a switch under the steering column panel, easy to get to and out of site.
You can tap into the start interrupt wire at the body control wire at pin 22 - light green (referring to 98 maxima FSM).
There are a quite a few ways of doing this. GL
Old Jan 26, 2009 | 06:41 PM
an alarm will do no good when someone steals your keys!
as for the fuse, thats a really good idea BUT would suck if the fuse got lost.
What I was thinking was hooking it up to the window lock switch
Old Jan 26, 2009 | 06:45 PM
Flava_24/7's Avatar
Boosted Panda
Stealing your keys? WOW. In all my years Ive never had that happen to me.
I always keep a small case of assorted fuses in my ride, so losing one really isnt an issue. Especially when the fuse box has a couple of empty slots to hold extras as well but do as you wish. Just trying to offer a super easy fix for a pretty simple issue.
Old Jan 26, 2009 | 06:56 PM
well right now i am sick, I took some cold medicine and my brother decided to take my car on a joy ride at 3am with no license or insurance
Old Jan 26, 2009 | 07:02 PM
2theMaX05's Avatar
Fuel cut or even maybe ignition cutoff
Old Jan 26, 2009 | 07:11 PM
it would be awesome to get an aftermarket alarm with an auxillary switch and hook up an electric fuel cut off to work on that switch BUT that want help my current situation. See my brother is a glorified drug addict and the police could care less, he took my car and I am now worried that they will be watching me.
Old Jan 28, 2009 | 06:21 AM
tallkid2201's Avatar
just wire a switch up to the wire connecting to the fuel pump fuse and then mount it under the dash so he cant see it. when youre worried, flip it off. hell never figure it out.
Old Jan 28, 2009 | 07:39 AM
G4nismo's Avatar
Old Jan 28, 2009 | 07:50 AM
mtrai760's Avatar
'Trynna' is not a word
This will fix your problem with your brother:
/endthread.
Old Jan 28, 2009 | 08:30 AM
look at my sig, that will fix my problem with my brother
Old Jan 28, 2009 | 08:54 AM
secondtonone317's Avatar
nycnissans
you can always put a switch on your crank / cam sensor signal and stash the switch somewhere.......or you can even get a keylock switch.
Old Jan 28, 2009 | 09:12 AM
Nopike's Avatar
Find the green with orange stripe wire, its for the inhibit switch that prevents the car from starting if the clutch has not been depressed or the car is not in P or N in the case of an auto trans. You should be able to find this wire under the dash near the clutch pedal if it a manual trans. Maybe similar location for an auto trans, I'm not sure. Cut this wire and your car will not start. Add a switch between the wires. If switch is on car will start if switch is off, no start.
Old Jan 28, 2009 | 10:04 AM
pmohr's Avatar
No more Maximas...
Is there some sort of problem with just locking your car and keeping your keys with you? Surely you have your own room, does it not have a lock on the door?
If not, buying a locking door handle is far cheaper (and you have less of a chance to screw something up) than trying to rig something up in your car.
Old Jan 28, 2009 | 10:10 AM
Flava_24/7's Avatar
Boosted Panda
Yeah, but thats not a cool as having an actual "kill switch" in the car. Plus you cant list a bedroom door lock as a mod......
Old Jan 28, 2009 | 10:38 AM
bedroom door locks are easy to open, credit card or knife work fine. IDK anyone that would list a kill switch as a mod
Old Jan 28, 2009 | 10:41 AM
pmohr's Avatar
No more Maximas...
There are more than a few people on here that list an oil change as a mod, much less a kill switch...
And depends on what kind of lock you get, and how you install it on whether or not you can easily get past it. With the proper setup, it's far easier to go through the door than open it.
Old Jan 28, 2009 | 10:49 AM
Flava_24/7's Avatar
Boosted Panda
Well you list your
NISMO S-TUNE HOOD STRIPE
DEBADGED TRUNK
CUSTOM PAINTED BLACK GRILL W/ CEFIRO STYLE MAXIMA EMBLEM
all as mods when one is just a sticker, the other is just the removal of an emblem and the third is just a grill painted black.... dont see how thats custom but O well. I could easily see you listing a kill switch as a mod.
Old Jan 28, 2009 | 10:50 AM
pmohr's Avatar
No more Maximas...
Well you list your
Old Jan 28, 2009 | 10:53 AM
Flava_24/7's Avatar
Boosted Panda
Exactly. He could get a keyed lock with a metal plate that blocks anything slipping it between the door jamb and the door thus eliminating the use of a knife or cc to open it. It is pointless to offer any other suggestions to him besides the kill switch since he is dead set on it and just wanted an excuse to justify it.
Hence what I said earlier to him about offering a super easy fix for a pretty simple issue.
Old Jan 28, 2009 | 10:55 AM
pmohr's Avatar
No more Maximas...
Exactly. He could getg a keyed lock with a metal plate that blocks anything slipping it between the door jamb and the door thus eliminating the use of a knife or cc to open it. It is pointless to offer any other suggestions to him besides the kill switch since he is dead set on it and just wanted an excuse to justify it.
Indeed. People always see the credit card trick in the movies or on TV, or use it on crap installs in apartments or whatever, and if they're just installed right...not to mention the inevitable damage to the card you use.
But yes, pulling the fuel pump fuse is quick and easy. Personally I think rectifying the family situation is the correct way, but
Old Jan 28, 2009 | 11:39 AM
Sinturion's Avatar
N00blargh
lol at using credit cards to open locked doors. Reminds me of back in high school when my friend tried to open up a teacher's office using his ID card. The ID card broke and left a picture of his face stuck in the door haha.
Old Jan 28, 2009 | 06:34 PM
well I shouldnt have to worry about this now since his PO told him to get her her money or else so.......
Old Jan 28, 2009 | 06:48 PM
nitromax's Avatar
so now worry if the car will be stolen & sold to settle a debt?!! call the "sig"!
Old Jan 29, 2009 | 07:09 AM
sig has been notified
Old Jan 29, 2009 | 11:28 AM
95max327's Avatar
hey where is the fuel pump fuse located on a 95 max? im about to do a compression test and cant find FP fuse!!
Old Jan 29, 2009 | 01:09 PM
G4nismo's Avatar
are you serious?
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
