Tranny Flush and Fluid Replacement options? or opinions? on whats best.
Old Jan 28, 2009 | 06:54 PM
Paz1986's Avatar
Tranny Drain and Fill and Fluid Replacement options? or opinions? on whats best.
*AUTOMATIC TRANNYS*
My car is a 98 with 131,000 miles.
Thanks in advance, kinda noobish question, tried searchin but would like to hear whats up, and what works right.
-Paz
Old Jan 28, 2009 | 07:02 PM
pmohr's Avatar
No more Maximas...
Don't flush, just drain and fill. If you drop the pan, clean the screen. Problem solved.
You say you 'tried' searching. Did it not work, or did you just give up on reading all of the posts you found? All the information you'd ever want to know is available through search, if you actually care to read it.
Old Jan 28, 2009 | 07:12 PM
Paz1986's Avatar
Yea, I meant tranny drain. idk why i wrote flush. ive heard thats devastating to do.
Im just curious about the right tranny fluid to use.
Old Jan 28, 2009 | 07:13 PM
pmohr's Avatar
No more Maximas...
Says in your owner's manual.
You could just use any old ATF, or you could bother to use Matic-D.
Old Jan 29, 2009 | 11:19 AM
Paz1986's Avatar
what's matic-d?
Old Jan 29, 2009 | 11:28 AM
ATTappman's Avatar
what's matic-d?
Nissan Matic-D is the OEM brand of automatic transmission fluid, available from a Nissan dealership. At least I assume it's available.
My local Nissan parts counter guy laughed at me when I asked for Matic-D. He told me it was just Dexron IIe/III, and to go to a parts store. I wound up buying Castrol Multi-vehicle Import. Said on the label it was equivalent to Matic-D. I couldn't find any ATF that said "Dexron III" on the label.
Old Jan 29, 2009 | 11:38 AM
trooplewis's Avatar
If you're going to go through all that work, you might as well spend the money and go with Amsoil ATF. Do a search for that and you will be reading for awhile.
Old Jan 29, 2009 | 02:37 PM
heynow's Avatar
https://www.amsoil.com/storefront/atf.aspx
I'd have gone with that. But i found out about after i flushed with Mobil 1 Synthetic ATF
rbuswell
Nov 17, 2016 04:54 AM
Chef N
Sep 22, 2015 11:20 PM
Ray229Harris
Sep 16, 2015 08:16 PM
doctorpullit
Aug 20, 2015 05:15 PM
Mrbizness1
Aug 18, 2015 08:43 PM
