Tell me my trans is not going bad. . .
Old Jan 26, 2009 | 07:51 PM
Spitzberg Beast's Avatar
Ok. . .95 max, 178k, auto trans
When I begin to drive she's ok until on/about 3000rpm. I hit the gas to accelerate but there's little to no acceleration, then the rpms increase to 6000. I have to keep pumping the gas in order for to drive. The gears for the most part fail to shift. The only time the rpms are low is she's not moving.
And today after about 2 hours of driving, I cant reverse and she drives in neutral. . .i know it sounds crazy but its true. I know I need my o2 sensors changed but i dont think it would be that serious. Can there be any other issue other than my trans?
Old Jan 26, 2009 | 08:04 PM
vqmaxman's Avatar
The first thing I would do Is, check the fluid level of the tranny and check what color the fuids are. I would than drive the car again and see what It does and see If It makes any difference and the sensors. IF the car does the same thing than you have a bad Torque Converter.
Old Jan 26, 2009 | 08:13 PM
krzymax's Avatar
Maxima owner since 2000
your trans is not going bad. . .
it's failing. =(
Old Jan 26, 2009 | 08:22 PM
Well I checked the fluid level and it was pretty low, then i topped it off but it's still the same
Old Jan 26, 2009 | 08:31 PM
vQmaxii's Avatar
yeah probably your torque converter
Old Jan 26, 2009 | 08:48 PM
vqmaxman's Avatar
Did you check the color of the fluid .(pink being extra clean and dark red or black being burnt is bad.) Which one of these are your fluid colors and have you ever flushed the fluids.
Old Jan 26, 2009 | 09:00 PM
How much does a torque converter cost and how much will it run me to replace?
Old Jan 26, 2009 | 09:04 PM
When i checked it, it was light red, almost pink. I have never flushed the fluid.
I've been researching over the net, the sypmtoms about a locked torque converter seem very similar to what i am experiencing. My first gear sometimes start at about 2000rpms.
Old Jan 26, 2009 | 09:17 PM
vqmaxman's Avatar
The best thing you can do from here on out Is rebuild your tranny or get a used one. If you do the Torque Converter you might as well do the seals and all the other things to get It back to shape. It's your call and your money. The fluid is fresh as what your stating in your statement.
Old Jan 26, 2009 | 09:23 PM
whlimi's Avatar
http://www.car-part.com/
You might be able to find a tranny in or near your area.
Old Jan 26, 2009 | 09:29 PM
How much would the cost difference be between replacing the torque converter vs. the transmission as a whole?
Old Jan 26, 2009 | 09:41 PM
pmohr's Avatar
No more Maximas...
If the torque converter failed then it's possible that it has been throwing trash through the trans as well.
I've been through that before - http://forums.maxima.org/4th-generat...inda-long.html
Old Jan 26, 2009 | 09:43 PM
pmohr's Avatar
No more Maximas...
Well depending on how much it costs you for a trans, it'll cost you the same amount of labor. You have to pull the trans to replace the TC anyway.
Personally I'd swap in a whole new trans. I went through...4 before I swapped out to a 5MT, best decision I've ever made with this car. With proper care and maintenance, they can last forever though.
Old Jan 26, 2009 | 09:52 PM
Wow. . .i think i have your old shoes on right now cause im in the same position. I guess the best thing to do would be to change the trans. . . . . .f***, im broke as s***, its like throwing salt in my wounds
Thanks yall
Old Jan 26, 2009 | 09:55 PM
4 trans damn. I wanted to get a manual but i need a car desparately so i rushed it. thanks for your advice.
Old Jan 27, 2009 | 08:30 AM
s14240sxsilvia's Avatar
I'm going onto my 4th trans now (It's in my backyard ready to be put int). I have the same problem but my CEL is on "Improper shifting to 4th gear". If I give it to much gas it slips but will only occur in 4th gear. I had bought a used trans and all was fine but now it's failing.....dam maxima transmissions.
Old Jan 27, 2009 | 08:31 AM
pmohr's Avatar
No more Maximas...
Are these all on the original solenoids, or have you installed the updated kit per the TSB?
Old Jan 27, 2009 | 08:33 AM
EEMaxima's Avatar
5-speed swap, without a doubt. This is your chance!
Old Jan 27, 2009 | 08:37 AM
ImmaSquashYou's Avatar
i bet that it drives a lot smoother now though huh?? lol....my tranny did the same thing. But my car also drives in park..so what i had to do was turn the car off while still in gear...and put it into park. then take the key out. and i will always park in a hill so i can put the car in neutral with the engine off, let it roll back..start the car and drive. I drove about 250 miles before i got the tranny changed...the car IS driveable..you just can parallel park, and drive it to places where you need to reverse...
Old Jan 27, 2009 | 10:07 AM
PM me details pls!
1st trans trans completely locked up got rebuilt at 60k
2nd/rebuilt original trans went at 120k. Threw "Improper shifting to 4th gear" code.
3rd trans pickup up from a used car parts place for 400 bucks. Worked fine at first but now is failing. Went bad in a month and a half so they gave me a new one because of the warranty.
Old Jan 27, 2009 | 10:21 AM
pmohr's Avatar
No more Maximas...
PM me details pls!
For the updated solenoids, it's part number 31940-80X25, $89.67 from Courtesy (about $50 cheaper than I paid for it a few years ago). The TSB that specifies this new PN says it only applies to '97s (NTB 98-049d), but there are TSBs for all of the other years explaining how to replace them (NTB 96-110).
IIRC it comes with the entire solenoid pack and a full set of pan bolts. If your current solenoids are faulty, it can fix a bunch of issues. For the cost and piece of mind, I'd probably throw it in any new trans I got.
Old Jan 27, 2009 | 10:50 AM
Thank you! This could very well be my problem. I will check the trans fluid. If it's pink Ill order this up. If it smells burnt I throw in the new trans and see how it drives.
I have an additional question. The trans I have that I will be putting in is from an infiniti j30. Can I use the same "kit"?
Old Jan 27, 2009 | 01:08 PM
J RO 9's Avatar
try the lucas transmission fluid additive. best $12 a ever spent when i thought my tranny was going to crap out on me.
Old Jan 28, 2009 | 05:30 AM
tallkid2201's Avatar
ya ive used the lucas fluid too. its holding in there....for now.
Old Feb 21, 2009 | 11:56 PM
Lickapimp8's Avatar
hey guys heres a link on how to replace those solenoids for those who wona do it themselves
http://www.jatan.net/tsbs/057053.pdf
Old Feb 22, 2009 | 08:42 AM
Rob_0126's Avatar
What mileage does the tranny in a 95 have this problem at?
Car has 112k on it. What causes these trannys to go like this?
Old Feb 22, 2009 | 09:05 AM
michaelp's Avatar
Automatics suck, esp Nissan automatics. Thats what causes them to go like this
I just finished a 5 speed swap in less than a week, but atm the clutch is being a ***** to bleed. Other than that, it was easy. (Thanks to those who answered any questions I had)
Old Feb 23, 2009 | 04:11 AM
Rob_0126's Avatar
bump, anyone?
Would like to know what makes these trannys go, so I can avoid this happening to mine.
Old Feb 23, 2009 | 08:23 PM
blktalon456's Avatar
Try to take off in low 1. I have seen some maximas and sentras need to be pulled down a little more into drive after some miles. I guess the cable stretches.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Marc2theMax
Sep 28, 2015 08:13 AM
