Starter Sig
Old Feb 3, 2009 | 08:24 AM
Abimax95's Avatar
Starter Sig
Hey guys I was going over my fuses and I notice that there is one fuse with no power I have change the fuse but nothing I can't remember the number but on the cover it reads Starter Sig or Start Sig I have search here and on line and the book but I fine nothing releted to this I have no idea what is for but right now there is no power to it .. any help will be appreciated ..
thanks
Old Feb 3, 2009 | 08:50 AM
pmohr's Avatar
No more Maximas...
'START SIG'?
Notice the 'ST' next to it, it only gets power when you're cranking.
Here's a recent post dealing with it:
Originally Posted by myke321
OMG!! What a pain the @$$ this has been - Today I was double checking everything, engine wires, fuel filter, battery, everything. I was checking the fuse panel diagram under the steering wheel against the fuses, and I noticed something I missed - THERE WAS NO FUSE IN THE "ST" SECTION! The 7.5 fuse that should have been there some how was moved in between "ACC" and "IGN" So I took the 7.5 fuse and moved it to "ST" and now my max fires right up!!! I have no idea how that fuse moved.
Thanks for everyone's help.
And for everyone that is having the same starting issue - Go check your fuse and make sure it's not blown or missing or damaged.
Old Feb 3, 2009 | 09:00 AM
Abimax95's Avatar
start sig
thanks pmohr I was hoping there was something wrong cuz i can't find anything else on my car .. it just doesn't want to start and i have replace everything I'm frustrated ...
thanks
Old Feb 3, 2009 | 09:35 AM
Nopike's Avatar
By won't start do you mean does not crank at all? Any clicking noise or just dead? Maybe a faulty starter or drained battery?
Old Feb 3, 2009 | 09:37 AM
pmohr's Avatar
No more Maximas...
He's got a couple of threads on it, it just doesn't want to turn over. Last I saw he had it narrowed down to an ECU issue.
Old Feb 3, 2009 | 10:33 AM
Abimax95's Avatar
is been almost two years since I drove my max I have replace everything ecu , coil packs spark plugs , groung starter , maf, both crank and cam sensors , fuel pump , injectors , wiring harnes , fuse block inside and all it does is turns and cranks but it wants to start but it will not I have a video to show what it does I have to download it .
thanks all for the replies
Old Feb 3, 2009 | 10:35 AM
pmohr's Avatar
No more Maximas...
You anywhere near KRRZ350? He'll have you back on the road...
Did it just not start one day? Or was there some sort of inicident that led up to this?
Old Feb 3, 2009 | 11:06 AM
Abimax95's Avatar
sorry I don't think so ... when I replace the engine the first time I start it it took about 3 to 4 cranks ..and it start it after that it would take 5 to 6 cranks and it would start i drove it for a week and once it starts it rive perfectly with no problem idle coun't be more perfect but after about 6 days later it will just crank and crank and if I keep cranking it back fires but it will not start I have try almost every subjection and nothing .. I don't want to get rid of my car sionce I have about $13,000 invested in it . plus I love my car hahaha ...
Old Feb 3, 2009 | 11:08 AM
pmohr's Avatar
No more Maximas...
13k? Damn.
In that case I'm sure it's worth you bringing up to Kevin...
Old Feb 3, 2009 | 11:20 AM
Abimax95's Avatar
yes I have everything in my car I drop about $9k on custommaxima.com and that doesn't include labor witch I did my self or rims and all the other stuff ... is he near MA and where can I get in touch with him PM me please with his info ... I appreciate the help
Old Feb 3, 2009 | 11:23 AM
pmohr's Avatar
No more Maximas...
http://forums.maxima.org/members/krrz350.html
Originally Posted by KRRZ350
PM or call 774-766-7462
3-bay garage in Massachusetts servicing all your maxima needs
Old Feb 3, 2009 | 11:31 AM
Abimax95's Avatar
start sig
thanks a million pmohr
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
