water pump
Old Feb 6, 2009 | 08:51 PM
97green's Avatar
water pump
I think that might water pump is leaking, but i am not sure ? I see coolant between compressor and oil pan . 97 with about 110k miles.. if it is a water pump how hard is to replace it.. ?? has anyone done it.. please let me know
thanks....
Old Feb 6, 2009 | 09:32 PM
NISSANMAXIMA91's Avatar
Dude. Have you not searched?
http://forums.maxima.org/4th-generat...placement.html
http://forums.maxima.org/4th-generat...teup-pics.html
Those only took 30 seconds to find using the SEARCH function. It CAN be your friend.
Old Feb 6, 2009 | 10:10 PM
TLMNICK's Avatar
Waterpump for sure....the pump itself is probably good, its the O-rings that die.
I've done two of them, and both times i just changed the whole pump.
Old Feb 6, 2009 | 10:21 PM
pmohr's Avatar
No more Maximas...
With the PITA spot it's in, I'd never swap out just the o-rings.
And OP: Yes, it is the waterpump.
Old Feb 7, 2009 | 11:04 AM
djengr's Avatar
My bet is on a waterpump, actually the water pump seal, but non the less the water pump needs to be changed.
Not a hard job, it is a tight fit. follow instuctions found in the sticky, get a new tensioner while you are in there. I did have to remove the engine mount and move the engine slightly.
Other than have some good gloves or band-aids.
good luck.
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
