Egr gasket forgotten after intake manifold assembly?
Old Feb 11, 2009 | 05:54 AM
porshapower928's Avatar
Hello I took off the intake manifold on my 95 se to replace the injector. After everything was done and I backed up the car there was a little metal type gasket with the round hold in the middle and one hole on each side for the bolts. Its definately a egr gasket of some type. On the rear of the manifold there were 2 bolts(support bolts) to the left and then there were 2 rear bolts(close to the tb) that held the egr (pick up tube?)..is there a gasket here that could have fell out? Thanks in advance.
Old Feb 11, 2009 | 06:07 AM
oldngivout's Avatar
Willing to learn
You nailed it. The EGR tube to manifold gasket is exactly what you are missing.
Old Feb 11, 2009 | 07:09 PM
I was afraid of that...geez looks like I have to take those bolts off and see if I can get it back in there.... What happens if I leave it out?? Thanks so much! Nel
Old Feb 11, 2009 | 07:26 PM
pmohr's Avatar
No more Maximas...
Then you will possibly have a large vacuum leak.
Not necessarily, but possibly.
Old Feb 11, 2009 | 07:30 PM
Snypa's Avatar
just re-do the job and get it in there.dont go experimenting w/o it
Old Feb 11, 2009 | 07:36 PM
turbizzy's Avatar
You don't need to redo the entire job, just removed the EGR pipe and clean off the gasket mating surfaces. This will give you a chance to clean out that EGR tube, which cloggs up all the time.
Old Feb 11, 2009 | 08:10 PM
Snypa's Avatar
not the entire job ofcoarse.
JonBlz
Oct 5, 2015 06:02 PM
atriuum
Sep 28, 2015 01:19 PM
dshinn
Sep 26, 2015 08:07 PM
Noela
Sep 26, 2015 08:22 AM
