95 tranny kickback into first, possible solution????
i was talking to a guy who works for nissan and he said there's a wire that if it comes loose even a little that it can cause kickback with auto trannys. he said you gotta drop the pan and drain fluid, then it has to be resoldered. could that be the reason for the kick into first??? c'mon pmohr, i know you got this
no, i actually meant 1st into second. it seems to take a little too long for it to catch. then i get like a hard shift, and she kicks back a bit when it grabs second gear. rest of the gears shift fine, but i tend to think there's a delay of some kind.
A bad line pressure SV would apply to all shifts, not just 1-2. Are you able to ask him which wire he meant?
ill find out tomorrow when he gets back to me. ill let you konw then. i am aware that the trans does have a bit of a kick, but this much??? i had a really hard 1 turning right going up a hill, but to be fair, she was'nt running temperature yet.
You learn something new everyday.... Mine does that too. I'll see what "good" fluid will do this spring. BTW my fluid looks fresh.
i was told theres a bad dropping resistor problem going on here. 50.00 part next to the fenderwall that exudes too much pressure which is causing the harder shifts. the resistor when working properly evens the flow therefore shifting into gear smoothly instead of kicking. trans is fine and this seems to be the only problem.
In any case, if it were failing, it would be apparent in every gear change, not just 1-2.
Unplug it and drive a short distance, you'll see how dramatic the line pressure is increased.
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
jchronis2552
Sep 21, 2015 05:52 AM
pktaske
Sep 4, 2015 08:40 AM
