bad alternator history, ignition seems weak, should i be concerned about this...?
Old Feb 18, 2009 | 02:19 PM
liloutlaws's Avatar
so my alternator broke down on me recently for the 2nd time. after the first time the mechanic installed a new re-built alternator. the car ran fine for almost a year, but it recently died again. lucky for me the rebuild part and labor was under warranty.
i just got the car back about a week ago and everything seems fine (like it did the first time). however sometimes when i start my car, it seems sort of laggy? it doesn't consistently give me a strong start. for the most part it seems okay, but i just seemed to have noticed that this was the case before when the alternator died the second time. is this even an alternator issue?
should i be worried? the battery is okay as well
95 GLE
thanks!
Old Feb 18, 2009 | 02:43 PM
titanbk's Avatar
sounds like it could use a ground strap to the starter from the negative terminal. Was the battery tested or is it just newer?
Old Feb 18, 2009 | 02:46 PM
liloutlaws's Avatar
so this issue has been around before the alternator died. the battery should be okay..only one year old?
wirelessdude04's Avatar
clean up your ground and ground your battery.. Maybe even use a ground kit
Old Feb 18, 2009 | 06:59 PM
liloutlaws's Avatar
sorry i'm still kinda noob at this....what am i looking for?
the mechanic said the battery was fine. i can clean up both the negative and positive terminal..but am i looking for something in particular?
spencerwh1
Jun 30, 2016 05:44 AM
mikeg75
Nov 30, 2015 05:12 PM
240tomax
Sep 13, 2015 03:28 PM
