DTC 0707 after running at the Pike last night
Nov 17, 2001 | 10:12 AM
Will I be fine running on a faulty Rear O2 sensor for a couple of weeks?
Nov 17, 2001 | 10:17 AM
Re: DTC 0707 after running at the Pike last night
is it continously on? or has it gone off?
Nov 17, 2001 | 10:26 AM
Re: Re: DTC 0707 after running at the Pike last night
Quote:
I reset the ECU and its off now.
It tripped the code when I was cruising home last night.
Nov 17, 2001 | 10:08 PM
bump
Nov 17, 2001 | 10:29 PM
Quote:
Originally posted by deezo
bump
A while back when my O2 sensor got busted Daniel B Martin told me not to run for long time cause it will fry my CAT converter. So I guess a 2 weeks wont do much unless you drive a lot.
Nov 18, 2001 | 12:12 AM
DTC 0707 is easy... everybody gets that... i looked in the fsm and it says "I beat Doug"
Nov 18, 2001 | 07:41 AM
Quote:
HAHAHAHA!!!!!!!
Nov 18, 2001 | 09:03 AM
4th gen FSM
Nov 18, 2001 | 07:03 PM
Quote:
Originally posted by Synki
4th gen FSM
Nov 18, 2001 | 07:08 PM
0707 Code
I'm pretty sure I have the same code with my car. I thinks its "rear heated 02 sensor", but mine was caused from using a 1995 modded JWT ECU in my 97. I havent had a problem with my car since it came on 8 months ago.
Nov 18, 2001 | 07:17 PM
Re: 0707 Code
Quote:
It is the rear o2 but after resetting the ECU, it didn't show back up.
Nov 18, 2001 | 07:40 PM
I've been running without a rear O2 for 8 months now... make your own conclusions.
Nov 18, 2001 | 08:02 PM
Quote:
Is it non-functional or did you remove it?
Nov 18, 2001 | 08:15 PM
If there is a problem the MIL will turn on again in a ~100 miles or so.
Nov 18, 2001 | 08:20 PM
I have the apexi catback so there is no hole for it... its just tied up down there
Nov 18, 2001 | 08:42 PM
TheBlue-Thats probally the secret to you running those great times
Nov 19, 2001 | 07:03 AM
LOL! Harsh, man...he found the nitrous problem.
Nov 19, 2001 | 07:07 AM
Quote:
no don't tell him.. he SHALL find out
Nov 19, 2001 | 08:38 AM
I heard that sprint didn't use his NOS quick enuf and it got old and didn't work. but that's ok, I've grown to expect amature mistakes from sprint
Nov 19, 2001 | 08:43 AM
That wasn't nice Aaron. Stop taking everything out of your car at the track, thats a newbie thing to do.
Nov 19, 2001 | 08:45 AM
Quote:
Anyone still watching the vid?
actually i had a NOS part leak.. not an install problem.. and maybe if i take my seats out.. i can run 12's
Nov 19, 2001 | 08:52 AM
I guess I need to work on my info links from the pike :-) if you think you can run 12s by taking out the seats then do it. You know you can't and this is why you just like to give the people who are fast a hard time.
Nov 19, 2001 | 08:57 AM
Didn't the nitrous get old or was it just your other problem Sprint?
Nov 19, 2001 | 09:16 AM
Me.
Nov 19, 2001 | 09:17 AM
Are you referring to me?
Nov 19, 2001 | 09:45 AM
no... I need somebody who can keep up and tell me the results... j/k maybe I should use you
Nov 19, 2001 | 10:10 AM
I am slow.
Nov 19, 2001 | 10:12 AM
I am slow.
so if you are slow and you can beat sprintmax then _______________ I know I give you guys a hard time, but you give it back just as much
Nov 19, 2001 | 10:22 AM
I'm joking with the I'm slow, hell my car is WAY faster now, and that's WITHOUT the NOS.
