HELP- SEATS WONT MOVE, WINDOWS WONT MOVE
Old 02-26-2009, 08:36 AM
K.Hall's Avatar
Like the title says, my seats no longer move(checked wires) and my windows wont go down. I know it could be a fuse or a relay but which one? I know the panel near my drivers side contains many fuses but the guidelines only shows you show little..So I was wondering which fuse number should I check for both the window/seats..Thanks alot....
98 Maxima!!!
K.Hall is offline
Old 02-26-2009, 10:01 AM
bigwee's Avatar
http://www.boredmder.com/FSM/Nissan/Maxima/1998/el.pdf
the service manual for the electrical system
bigwee is offline
Old 02-26-2009, 10:09 AM
Nopike's Avatar
Check fuse "f" it's a 30 amp fuse its located in the underhood fuse box. There are a few 30amp fuses there check them all.
Nopike is offline
Old 02-26-2009, 10:14 AM
92gxe/cg2's Avatar
Its not that hard, look on the pull off fuse cover (if you have it) and look for fuses for the interior electrical system, one might even be labeled windows or seats. Or pull them all out and check for blown ones, even that wont take more than a few minutes.
92gxe/cg2 is offline
Old 02-26-2009, 10:23 AM
J RO 9's Avatar
make sure your windows aren't locked by the switch on the driver door. it happened to me once.. i was freaking out and i realized i pressed it
J RO 9 is offline
Old 02-26-2009, 10:28 AM
Nopike's Avatar
That 30 amp fuse I mentioned is actually a fusible link, it's much larger than a fuse, it's located in the underhood fuse box. It's one of the few things that will take out both the windows and the seats. How did the problem start? Were you or someone else working on the electrical system?
Nopike is offline
Old 02-26-2009, 11:27 AM
K.Hall's Avatar
^My vehicle was involved in a minor car accident which resulted in me needing a left fender and door..(fuse box was slightly moved)...Alright, so if that doesnt fix the problem, worse case scenario?
K.Hall is offline
Old 02-26-2009, 11:50 AM
K.Hall's Avatar
THANKS ALOT GUYS
K.Hall is offline
Old 02-26-2009, 12:37 PM
Nopike's Avatar
Might just be bad connection of the fusible link "f" at the underhood fuse box. If the link is blown you can try replacing it. If it blows again some of the power wiring may have been shorted or disconected. If the fusible link does not fix it check the wiring running to/under the link. This should not be a big deal just an open or shorted wiring/circuit.
My guess is that the link or wiring got moved and is not making contact so it is not providing power to those circuits.
Nopike is offline
Old 02-26-2009, 12:43 PM
Nopike's Avatar
Since the fuse box is so close to the fender it may have gotten damaged or whoever replaced the fender may have left something out or not connected it properly.
Nopike is offline
Old 02-26-2009, 06:16 PM
Maximum-Maxima's Avatar
What I did when one of my fuses went out is pulled each one and placed it back that way you'll find it. The way you can tell it is bad is if the metal part in the middle of the fuse is melted or not touching.
Maximum-Maxima is offline
Old 02-26-2009, 06:18 PM
Stormzusmc's Avatar
dude, i heard about this....it usually means your engines electrical system is messed up..didnt you search? youre better off getting a new car...
Stormzusmc is offline
Old 02-26-2009, 06:48 PM
K.Hall's Avatar
^LOL, good one...I fixed the windows, now i need to mess around to find out whats up with the seats....Which fuse or relays should I check? Thanks alot guys
K.Hall is offline
06-06-2017 02:01 PM
carid
09-17-2015 05:00 AM
ik95
09-16-2015 08:11 PM
Quick Reply: HELP- SEATS WONT MOVE, WINDOWS WONT MOVE
