LED GAUGES semi Failure
Old Feb 28, 2009 | 01:59 PM
MaxFanatik's Avatar
Hey so a friend of mine installed brite white LEDS in my gauge cluster. Butttttttttt my whole cluster lights up blue ((
I have a GXE cluster, and it has some sort of like blue painted on film i guess behind each gauge... any1 kno if thats all guages and if i can take that off?
Old Feb 28, 2009 | 02:55 PM
G4nismo's Avatar
its prob b/c of the tint. same thing applies to the auto gear display shifter.
can't really do anything, if you try and scrape it off, your most likely going to mess up the displays. just leave it alone
Old Feb 28, 2009 | 03:09 PM
wirelessdude04's Avatar
yea no way around it.. Just get a SE cluster and call it a day
Old Feb 28, 2009 | 03:19 PM
MOHFpro90's Avatar
An SE cluster wont help. Any white face gauges have a blue backing to them. The black face gauges however, have no tint.
Old Feb 28, 2009 | 03:21 PM
aznprid972's Avatar
I saved this pic from along time ago in a post and whoever it was mentioned sanding the back of the gauges to remove the tint. I can't confirm it'll work because I have yet to try it. Looks like you would have to remove your needles to remove the gauge faces so proceed at your own risk.
Old Feb 28, 2009 | 03:23 PM
aznprid972's Avatar
My black face gauges does have a tint on them as well. I replaced the bulbs with some hyper white bulbs a while back and all the gauges have either a tint of blue or purple in them.
Old Feb 28, 2009 | 05:15 PM
JNCoRacer's Avatar
Just the tip.
Yeah didnt someone also mention using a mild solution of acetone to wipe it off too? I may be mistaken though, seems like it would melt the plastic.
Old Feb 28, 2009 | 06:49 PM
MaxFanatik's Avatar
that is untrue, my freinds SE white guages do not have it... but my BLACK gxe guages do =(
Old Feb 28, 2009 | 10:10 PM
MOHFpro90's Avatar
Correction on my part:
The Black gauges do have them, however on 3 of the 4 gauges, the blue can be removed. The speedo's blue tint is actually the plastc itself.
Fanatik, Not sure how your friends white SE gauges dont...mine do...
Old Feb 28, 2009 | 10:46 PM
LiGhtSoUt's Avatar
i was the one who posted those pictures i used sandpaper because it was easy and it came out great just take your time with it yes acetone will work too
Old Mar 1, 2009 | 06:18 AM
But he said " I have a GXE cluster, and it has some sort of like blue painted on film i guess behind each gauge...".. Correct me if i'm wrong but aren't GXE cluster's black?
Old Mar 1, 2009 | 06:19 AM
^^^^^ edit seen you just responded to maxfanatik
Old Mar 1, 2009 | 08:01 AM
Kevlo911's Avatar
Kevlo for President
The blue only comes off the tach..
That is why 3 out of my 4 guagues are blue
Old Mar 1, 2009 | 11:22 AM
MaxFanatik's Avatar
did u use acetone.. and what grade of sandpaper you used and did you need to take of the needles?
Old Mar 1, 2009 | 11:54 AM
fat_kid's Avatar
put a yellow filter on the bulbs, it should cancel out the blue from the gauges and make white light, try that first and then get yellow leds if it works
Old Mar 1, 2009 | 01:33 PM
MaxFanatik's Avatar
where can i get a yellow filter? like yellow saran wrap sort of deal?
Old Mar 1, 2009 | 01:52 PM
fat_kid's Avatar
something to that sort, yes
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
