ASAP question - CEL with ignition on or no?
Old Feb 28, 2009 | 03:16 PM
James92SE's Avatar
2 VE's are better than one!
A friend of mine is looking at a 96 Maxima, and we're suspicious of the reason why it won't pass emissions. The question:
When the key is in the ignition and/or on the "on" position, shouldn't the check engine light be on and then go away when the engine starts up? My 3rd gen does this as well as all other cars I've been around.
We're concerned it has a code(s) or emissions problems and the CEL light has been disabled. TIA!
Old Feb 28, 2009 | 05:12 PM
SKOLJACK's Avatar
The vehicle should perform a bulb check upon start up and the CEL will only illuminate temporarilly then go out (if NO faults are stored)!!! The bulb could be burned out or missing. Find a way to pull codes from the ALDL connector to be sure no codes are present!
Old Feb 28, 2009 | 08:23 PM
pmohr's Avatar
No more Maximas...
You a GM guy? We don't have an ALDL connector, that's GM specific.
But correct otherwise.
Old Feb 28, 2009 | 11:35 PM
em2_walsh's Avatar
I had the same thing, you might have a 'Service Engine Soon' light next to where the CEL would be, and as far as I know, that served the same purpose because it was on when I had codes and it went off when I got rid of them.
Your best bet is to go to Autozone and get your codes checked.
Old Mar 1, 2009 | 06:14 AM
SKOLJACK's Avatar
Originally Posted by pmohr
You a GM guy?
No! But most of my training has been through ASE which is based off of a lot of GM terminology. So my terms may differ at times, the end result will be the same!
JoshG
51
Sep 21, 2015 10:41 PM
chernandez1278
Sep 16, 2015 01:18 PM
rnb754
Sep 14, 2015 11:39 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
