95 Maxima throwing codes ECT/EGR
Old 03-06-2009, 12:26 PM
  #41
No more Maximas...
pmohr's Avatar
You can ohm the rear injectors without pulling the UIM, but you'll have to do all 3 and compare, not look for an absolute value.
pmohr is offline
Old 03-06-2009, 01:36 PM
  #42
95slowMaxima's Avatar
how do you do that pmohr?
95slowMaxima is offline
Old 03-06-2009, 01:57 PM
  #43
No more Maximas...
pmohr's Avatar
There's a connector on the far right side of the engine bay, right next to where the engine harness bends around the strut tower. That feeds the CKPS REF and the rear bank of injectors. You can ohm out the injectors through there, but looking for a difference in value, not an absolute value (because the harness will add some resistance to the measurement).
Take a look in EC, the pinout is in there.
pmohr is offline
Old 03-09-2009, 07:14 AM
  #44
ATT----------
Can you clear this up for me?
I am about to order the Valve ASSY-Slenoid that you sent me a link to. Before I do so I wanted to ask you something. Is it attached to the EGR? I was thinking if it's actually attached to it when you order a new EGR then perhaps I should get the whole assembly for the extra money. This way it's new and next month I don't throw another code requiring me to replace the whole thing any way.
If it is not attached to it or does not come with it when ordering the EGR itself and it's infact seperate then I will just order the part that you gave me the link for.
Thanks for clearing this up.
Old 03-09-2009, 08:31 AM
  #45
ATTappman's Avatar
The EGR control solenoid valve and the EGR valve are completely different parts - one can fail while the other is just fine. A 1004 code indicates a problem with the EGR solenoid valve/circuit. So if you order the EGR control solenoid valve ONLY, you should be OK. You will get that part only, they will not send you an EGR valve too. Or if they do, you will have gotten a great deal.
Edit: A 1005 code, not 1004. My mistake.
ATTappman is offline
Old 03-09-2009, 09:25 AM
  #46
Thanks ATT for clearing that up.
BTW I am throwing a 10 05 not a 10 04. Did you just happen to hit the 4 instad of the 5? I am going to order this part when I get a break.
I read in the EC part of the manual (page 180 on) that the EGR Solenoid is one of many parts to check when you have a cyl misfire. I am hoping by replacing this part is clears my other code.
Old 03-09-2009, 07:14 PM
  #47
Ordered the part. Let's hope I can install it late this weekend and it solves my issues. any good how to's on installing this piece?
Old 03-09-2009, 07:26 PM
  #48
No more Maximas...
pmohr's Avatar
Should only take you 15 minutes or so. Just take a look at the area, it's very simple.
Should just be a single 10mm head nut and 3 vac lines.
pmohr is offline
Old 03-09-2009, 08:02 PM
  #49
ATTappman's Avatar
I used a 10mm flexible head ratcheting wrench (gearwrench). You can buy one at Lowes or Ace Hardware for about $10. I couldn't get a regular wrench into the hole between the lower intake manifold and the solenoid valve, and I couldn't get anything but the four fingers of my left hand down in there anyway so I couldn't have turned it without my thumb. I swiveled the flex head wrench to a 90 degree angle, put the head of it on the nut with the index and middle fingers of my left hand, and turned the wrench with my right hand. Once the nut was off, I promptly dropped it and had to get it with a magnetic pickup. Be careful not to tear the vacuum hoses.
It took me a good half hour of making failed attempts with a regular wrench and a socket wrench, then a trip to the hardware store for the flex head wrench, then another 30 minutes to actually do it. I'm an engineer, so not so good with hand tools.
Old 03-09-2009, 08:23 PM
  #50
Thanks. Once I get the part in I will have to go to lowes so I can make the job easier. Plus I get a 10% military discount, all the more reason to go. I will post back once I replace it.
mrc00l88
01-25-2024 01:14 PM
lux97Max
19
08-27-2015 07:48 PM
doobadoo
08-15-2015 06:43 PM
wingnut2006
08-15-2015 04:16 PM
jholley
08-11-2015 09:38 AM
Quick Reply: 95 Maxima throwing codes ECT/EGR
