Starter Not Cranking Engine
Old Mar 11, 2009 | 11:41 AM
azn_mint's Avatar
Hello Everyone,
I could not start my car this morning when everything was working great until this morning. I had a problem with my car not starting a few months back, but it was because I had my clutch changed and I had to re ground my wires to the tranny and starter.
Which worked wonders! But then today I cranked the engine and all I hear is a whirring or whizzing sound and my rpms rev but no crank! I just replaced my battery and my starting is 2 months old. I not sure what it is. It almost sounds like the starter is spinning but not engaging the flywheel to crank the engine?
Any help or thoughts would be appreciated! Thanks
Azn Mint
Old Mar 11, 2009 | 11:54 AM
pmohr's Avatar
No more Maximas...
So the tach moves, but the engine isn't cranking? Odd electrical problem.
Did you do anything other than replace the battery right before this happened?
Well, disregarding the tach issue, pretty much it's one of three things; you have zero compression in all cylinders, the ring gear somehow separated from the flywheel, or the bendix gear isn't kicking out far enough.
First thing I would do is pull the starter and bench test it, see if it's kicking out.
Old Mar 11, 2009 | 12:10 PM
Bassbreaker's Avatar
^ +1
Had similar problems with my auto when i rebuilt the starter...only i had a 5-speed bendix gear in and it wouldn't kick out enough to crank the motor
Old Mar 11, 2009 | 12:16 PM
pmohr's Avatar
No more Maximas...
Originally Posted by Bassbreaker
^ +1
That's odd, because the auto and 5 speed starters are identical (and the same for the internals).
Old Mar 11, 2009 | 12:19 PM
fflint_18's Avatar
Could be the Starter solenoid which is what pushes the bendix gear against the flywheel or as others said the bendix gear itself. But if the gear was going bad you would have had indications.
If you hear a spinning motor nioise my bet is the starter solenoid.
Old Mar 11, 2009 | 12:23 PM
weird...I brought 2 bendix gears up to a rebuild shop...well 2 starters actually...to make one. When I got the starter back,it would kick out, but not enough to reach. So, I got back the other bendix gear from the other starter, put it in myself, and away I went.
Old Mar 11, 2009 | 12:24 PM
time to push button start
Old Mar 11, 2009 | 02:50 PM
azn_mint's Avatar
Well I took my starter out and took it to a rebuild shop and he says the drive shaft of my starter is bad or loose. It spins but when he applies some pressure to it, it just too weak to crank over the flywheel. He says he has a used one he can put in for me... so I 'm just going to wait till tommorow to get it back and see if it solves my problem. Hopefully it will be the same length bendix gear cuz the one he showed me looked a little shorter.
But i'll update everyone on how it goes.
Thanks again for your inputs!
Old Mar 11, 2009 | 04:40 PM
titanbk's Avatar
this would have made for some cool pics.......
would have sucked for you though
mvm062
Nov 30, 2020 09:00 AM
97_GXE
Sep 15, 2015 06:47 AM
rnb754
Sep 14, 2015 11:39 PM
ballerchris510
Sep 11, 2015 05:29 PM
conansriver
Sep 11, 2015 10:26 AM
