Weird Chassis sound?
Old Mar 16, 2009 | 01:07 PM
JUDE's Avatar
Maxie is getting old. She's making all kinds of sounds!!!
New one seems to be like birds chirping from the back. It only does it when moving. In the beginning, it was only on bumps, now it seems to be all the time. Not sure what it is. Any ideas?
Old Mar 16, 2009 | 01:11 PM
Quickywd01's Avatar
Rear sway bar bushings. It could be other things as there is many components there and your description is not descriptive enough to tell exactly what it is.
Old Mar 16, 2009 | 06:37 PM
Nozama's Avatar
Grumpy old guy
Sway bar bushings? I don't believe 4th gens have rear sway bars unless there's an aftermarket sway bar installed.
Old Mar 17, 2009 | 06:38 AM
Quickywd01's Avatar
Any guess was a good guess at that point.
Old Mar 17, 2009 | 06:53 AM
av8orjb's Avatar
Check your car jack in the side compartment of trunk. If its not tight in its holder it will squeak.
Old Mar 17, 2009 | 07:53 AM
JUDE's Avatar
No aftermarket sway bars. Trunk jack is in really tight. Not sure how to better explain the sound. I'll try to make a sound clip or video.
Old Mar 17, 2009 | 11:44 AM
97maxcades's Avatar
get a video up
Old Mar 17, 2009 | 12:28 PM
Nozama's Avatar
Grumpy old guy
Chirping could be the brakes if they are down to the wear indicator (piece of metal on the pad that rubs against the rotor when the pads are low enough)
Or wheel bearing.
That's the two best bets.
Old Mar 17, 2009 | 01:24 PM
98maxse5spd's Avatar
I know that squeak well, both of my 4th gens have/had it. I haven't figured it out yet, but it does sound like a swaybar squeak. My current car has an aftermarket bar and the old one didn't. Same squeak.
Old Mar 17, 2009 | 06:48 PM
titanbk's Avatar
its VERY uncommon for the rear swaybars to make any kind of sound on these cars, but you never know.
get a vid or maybe a few more details. Is it ALL the time, after driving for a while, cold, hot. Is it worse under any certain road conditions?
Old Mar 17, 2009 | 09:45 PM
matrix11229's Avatar
I had that noise before. Turned out to be a torn bushing that holds the exhaust (the L pipe I guess).
Old Mar 18, 2009 | 05:07 AM
Hollis's Avatar
tighten ur jack in ur trunk as much as u can I did that and it stopped.
Old Mar 18, 2009 | 06:22 AM
1chewabacha1's Avatar
Steps to solve your chirping trunk issue.
1) Look around in your trunk for the bird nest. I know it may seem crazy but if you look hard enough I'm sure you'll find a nest of baby birds in your trunk.
2) You have two options:
- (A) Just throw the nest away, killing the baby birds
- (B) Place the nest in a safe location and raise them as your own children.
3) Enjoy the chirp free ride!
Seriously though, Assuming you've made sure all trunk items are secure, I'd jack up the car and check all of the rubber bushings in the rear end area. It's always a rubber piece that has deteriorated causing metal to slightly rub other metal causing the chirps.
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Apr 16, 2020 05:15 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
