need help fast
Old Nov 5, 2000 | 08:49 PM
cml325's Avatar
hi does anyone no how to put in the door speakers in the 95 maxima cant figure out how and aslo the rea ones thannks
Old Nov 6, 2000 | 10:47 PM
Are you replacing your factory speakers. If so, do you know how to get to the speakers for the front and the rear. If not, you will basically have to take the panel of the door off in the front and take out the seat in the back to get to your speakers.
Old Nov 6, 2000 | 11:08 PM
Surge Diesal
Taking out old speakers
For the fronts you need to remove the door handle (screw in the middle, then like three more screws along the bottom, pop off the door and you'll see the speaker screws.
For the rears I went at the honeycomb covers with a knife till they were destroyed, there is then the matter of some screws, but 6x9's wont fit in the rear, suck. You will need to slice open bigger holes for any serious equipment.
After doing all this I looked over the stock (non-BOSE) speakers, 5W Panasonic pieces of s**tang. They did sound decent though I have to admit. This post should probably belong in the Audio section but hey good luck.
Old Nov 6, 2000 | 11:47 PM
You need to take the seat out in order to get to the speaker. First the base of the back seat will need to be removed. To do so, pull out on the two tabs right under the seat. There should be one under each side of the seat(Just take a look underneath). After that, take the backrest off. There should be two nuts that you'll need to remove. They should be on the bottom of the backrest and near each of the back door. Then, pull open your arm rest in the middle, and pull the clip that extends form the arm rest off from the frame of the backseat. There should be 2 screws there. Unscrew them and then pull the seat upwards to remove it. Then, snap the side panels off where the seat belt comes out of. Just to let you know, they're in there pretty tight. After that you should be able to pull the board to get to your speakers.
lrb6805
Sep 30, 2015 08:12 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
