Overheating not a problem
Old Nov 19, 2001 | 09:55 PM
Agressive Racin
ok i just got the thermostat fixed. the thing still aint heating up.
and if i touch the hood/engine/upper/lower rad hose it isnt hot enough.
what is wrong any suggestions?
i also have a clicking noise when i am stopped and i turn the wheel
i dunno if it could be the cv joint since i am not moving.
and i have excessive clutch chatter?
normal for a car with 87k miles?
Old Nov 19, 2001 | 11:28 PM
Chunger's Avatar
My other car is a Hybrid
I'm stumped by the underheating problem...
Clicking? I'm not sure if the PS pump makes a noise if you leave it fully turned and not moving... At least I've never noticed it. NE1?
Clutch chatter could be caused by the 87K clutch...
Old Nov 20, 2001 | 05:58 AM
dwapenyi's Avatar
Re: Overheating not a problem
When do you touch the hose?? Is it after a short trip to the grocery?? The cooling system concentrates on cooling the heads, and the heads only really do some work on the highway. Try a high speed romp on the highway and then check your hoses afterwards.
DW
Old Nov 20, 2001 | 09:38 AM
sinewave's Avatar
The '99 FSM has plenty of diagnostic procedures for overheating, but not overcooling. One other possible cause is the cooling fans, the temperature sensor or the fan relay.
The cooling fans are 2-speed. Check to see if they are both running with the car not moving and the a/c off. The fans should NOT be on if the radiator coolant is below 203 deg. F (95 deg. C). They should be on low speed between 203-221 deg. F (95-105 deg. C) and on high above that.
If your fans aren't operating within those parameters, PM me and I will send you the pages on troubleshooting the circuits.
Old Nov 22, 2001 | 05:47 AM
Agressive Racin
Re: Re: Overheating not a problem
DW
i am thouching the head after a 1 hour ride along the njtp at 100 and its still slightly cool
Old Nov 22, 2001 | 05:48 AM
Agressive Racin
the fans are off
it gets warm but the car has to be at a light
and it also takes 15 mins for the car to get out of cold and into 1 mm above the cold line...
Old Nov 22, 2001 | 09:13 AM
sinewave's Avatar
How much do you trust the mechanic that supposedly replaced your thermostat? It looks like it's pretty easy to get to the thermostat. Why don't you pull it yourself and put it in a pot of boiling water to test it?
Old Nov 22, 2001 | 10:24 AM
Agressive Racin
i am waiting for another thermostat
again nissan oem
it should be here monday
Old Nov 22, 2001 | 10:48 AM
dwapenyi's Avatar
Sounds like your thermostat is stuck open, or maybe the mechanic removed it completely? I had toyota dealer do that to my previous car, ba$5tards. They gouged out the thermostat and left a hollow shell. I found out later when doing some maintenacne on my car. The car warmed up very very slowly, too.
DW
the fans are off
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
homewrecker
Sep 24, 2015 07:01 PM
