Throttle Body bolts
Throttle Body bolts
I just cleaned my TB today .. how bad is it to overtighten these bolts?
I normally follow the tightening order like below for most parts but it was late and my back was killing me from leaning over.
Should I unbolt and tighten to spec? Will I need a new gasket if I do that?
Should have replaced your ERG valve while you had the thing off. It's a common failure on Maximas.
I would loosen the bolts and tighten them to torque spec. You won't damage the bolts (unless you over-tightened them to death), but because of heat expansion you can wear out your gasket prematurely. Get a long socket extension, it makes life a lot easier under the hood
Also, you should be ok if you put a new gasket on when you put it back together, so no need to replace it.
OP: The exact proper torque spec and sequence for the TB bolts doesn't really matter, honestly. As long as they're tight/snug, it'll be fine.
REDinLV
08-15-2024 01:30 AM
litch
123
01-04-2024 08:01 PM
knight_yyz
11-01-2015 02:34 PM
RealityCheck
10-02-2015 07:34 PM
