both front wheels lock up
Old Apr 16, 2009 | 01:40 PM
stan's Avatar
my front wheels keep locking up. i've changed the master cyl and calipers. the more i use my brakes the quicker wheels lock up. trying to find where to start looking for the problem. any help would be appreciated.
Old Apr 16, 2009 | 01:49 PM
pmohr's Avatar
No more Maximas...
The more you use them as in the more you apply them in any given situation? Or the more often you use them over a period of time?
Do you have ABS? Did you not replace the brake hoses? If you did the master cylinder and all of the calipers, you should've done the hoses at the same time.
If you're slamming on the brakes and they lock up, then your problem isn't mechanical, it's driver error...
Old Apr 16, 2009 | 01:57 PM
stan's Avatar
when i apply the brakes. if i stopped at five stop lights applying the brake, by the 5th light the wheels will be locking up. there are all new hose's on there as well. problem is definitely mechanical. i'm thinking something is not releasing when brakes are applied. trying to get idea where to start looking.
Old Apr 16, 2009 | 01:58 PM
pmohr's Avatar
No more Maximas...
So again...ABS?
Old Apr 16, 2009 | 05:24 PM
brandnew's Avatar
Originally Posted by pmohr
So again...ABS?
maybe abs sensor? long shot but are ur wheel bearings in good shape just a thought
Old Apr 16, 2009 | 05:34 PM
stan's Avatar
no. it doesn't have abs
Old Apr 16, 2009 | 08:16 PM
EnervinE's Avatar
i has college
By the time your wheels are locking up, is acceleration suffering? Does the brake pedal get harder to push?
Old Apr 16, 2009 | 08:43 PM
stan's Avatar
yes. thats exactly what happens, both the loss of acceleration and pedal hardens.
Old Apr 18, 2009 | 02:03 AM
yeah, thats my max's Avatar
same thing happens with mine... only if brakes r slammed on though...driver error???
Old Apr 18, 2009 | 08:56 AM
MOHFpro90's Avatar
I really dont know much, outside the calipers/rotor area, but it sounds to me like the power brake pump is going. You know how when you turn the car off, and pump the brakes and it gets stiff and locks up? It does that because the car isnt on, when you do turn it on, the pressure is released. Well it sounds exactly like that, just with the car being on...
Old Apr 18, 2009 | 09:10 AM
blktalon456's Avatar
Change the hoses on both sides. What has happened the fluid go go in the caliper but can't come back out due to a blockage. Over time the inside of the hose breaks down and chuncks of material get caught in them.
Old Apr 18, 2009 | 09:12 AM
pmohr's Avatar
No more Maximas...
I figured the same, but if you read the thread:
Old Apr 19, 2009 | 03:10 AM
96i30azn's Avatar
maybe try a bleed
Old Apr 19, 2009 | 10:18 AM
I posted without fully reading. I gave a suggestion that I knew could be the problem. My bad.
homeyclaus
Sep 3, 2015 06:15 PM
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
kjm900r
Aug 5, 2015 07:14 AM
BassAddictJ
Aug 4, 2015 11:38 AM
