Tem switch electrical issue
Old Apr 20, 2009 | 09:11 AM
ish's Avatar
ish
My Temp gauge has not been working for some time since buying the car.
I recently changed both the temp sensor and the temp control switch but ran into an issue. The little plug that connects to the temp switch is broken. Cable disconnected from the harness.
Obviously i need to replace it. But it has a long cable and i dont know where it connects to. Thinking of splicing and reconnecting to a new one. Any ideas on how to fix for good.
Thanks in advance.
Old Apr 20, 2009 | 09:18 AM
pmohr's Avatar
No more Maximas...
By 'temp switch' are you referring to the ECTS, or the gauge cluster temp sensor?
Basically, the two pin connector or the spade connector?
Old Apr 20, 2009 | 01:16 PM
ish's Avatar
ish
good question. Its the smaller of the two. Sorry about that.
Old Apr 20, 2009 | 02:13 PM
pmohr's Avatar
No more Maximas...
Just find a spade connector that'll fit the gauge cluster temp sensor, and put it on the remaining length of harness that's left.
Preferably clamp it on, then run some solder through it to ensure a good connection. And even better will be a spade connector with a rubber boot over it.
Old Apr 20, 2009 | 04:04 PM
ish's Avatar
ish
Thats the problem. Its disconnected at the harness. The harness is also cracked and broken. Id rather change all.
This is the part that the harness is broken for.
http://www.autozone.com/autozone/cat...entId=cat10009
Old Apr 20, 2009 | 04:07 PM
pmohr's Avatar
No more Maximas...
The only way to change out that specific harness is to either rip open the engine control harness, or get a whole new engine control harness.
So there's absolutely no wire left where it comes out of the main harness? Nothing for you to splice into at all?
Old Apr 20, 2009 | 04:42 PM
ish's Avatar
ish
nope it came out of the harness. the whole thing. I figure i get a harness with some wirel and splice the 2 together. What do you think?
Old Apr 20, 2009 | 04:48 PM
pmohr's Avatar
No more Maximas...
Can you take a picture?
The only thing you can do if it is indeed as you describe is open up the engine control harness and join up to whatever part of the wire is left.
Old Apr 20, 2009 | 04:57 PM
ish's Avatar
ish
Ill have one tomorrow as its night and raining. So far the car is good but you never know sometimes. When its least expected. the temp may spike.
Old Apr 23, 2009 | 07:52 PM
ish's Avatar
ish
Ok i finally got the pic. It stopped raining. Here it is.
Let me know what you think. The cable is hanging off to the side. It broke from up top.
Thanks for all your help.
Old Apr 23, 2009 | 08:10 PM
pmohr's Avatar
No more Maximas...
Can't really tell much from the pic, odd angle and grainy, can't even see the remainder of the harness.
But if it did indeed completely break off at the engine control harness, like I said you only have two options; open it up and solder to the remainder of the harness, or run a new wire all the way inside the car.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
