My car dies while shifting gears, wont pass 3000 rpms
Old Apr 27, 2009 | 08:32 PM
zzmasta06's Avatar
Hey guys. I got a problem and dont know whats going on. My ECU said i needed a new maf sensor (mass air flow sensor) and once i installed it, the ECU said i needed one still, and the problem of my car did not fix.. The problem is
Sometimes, when i start up the car, it wont start at all, and when i do start it, the rpms are around 1000 to heat up. Once i shift gears, my car sometimes stays on, or just dies. It is on for a second, and then dead. Also, when i rev up the car, it wont pass 3000 rpms, it only comes near it.. It also jumps from 2000 rpms to almost 3000. Once it does that, my car starts struggling and shake. My mechanic doesnt know whats wrong and is going to talk to his mechanic friends. I hope its not anything with the transmission.... or else its to the stealerships.............i mean good ol' dealershipp.. :\
Old Apr 27, 2009 | 10:17 PM
WhiteMaxima9600's Avatar
That sounds like a typical maf sensor failure. But if u installed a new one it should have begun to run normal. Did u try reseting the ECU??
Old Apr 28, 2009 | 06:13 AM
dallas0593's Avatar
+1... you need to reset the ecu after replacing a maf that threw a code.
Old Apr 28, 2009 | 06:26 AM
pmohr's Avatar
No more Maximas...
Did you check anything first, or just replace the MAF assuming that was the problem?
Assuming you cleared the codes and the MAF code came back, then it's likely a harness issue. Some have fixed issues like that by grounding the MAF, or it could be some corrosion within the connector, a damaged wire, etc.
Old Apr 28, 2009 | 06:52 AM
zzmasta06's Avatar
Il try resetting it, but how would that help? Yes my check engine light came. It gave me the code for a maf sensor.
Old Apr 28, 2009 | 07:30 AM
pmohr's Avatar
No more Maximas...
No, did you reset the codes after you replaced the MAF?
Old Apr 28, 2009 | 09:59 AM
zzmasta06's Avatar
No i did not reset it after installing my maf sensor... I bought the mass air flow from a junkyard, guaranteed to work.
Old Apr 28, 2009 | 11:18 AM
pmohr's Avatar
No more Maximas...
Then do so, see if the symptoms are still there, and if the code comes back.
Instructions are in the stickies.
Old Apr 28, 2009 | 12:12 PM
VANGtastic97's Avatar
My car had similar problems when I installed the TPS on backwards...
Old Apr 28, 2009 | 02:55 PM
zzmasta06's Avatar
can you help me define what a tps is?
Old Apr 28, 2009 | 02:57 PM
zzmasta06's Avatar
and il try that, thanks pmohr. il let you know how it goes
Old Apr 28, 2009 | 03:05 PM
TPS= trottle position sensor
It's attached to the trottle body, near the maf sensor. I doubt that is the problem though if you never touched it.
Old Apr 28, 2009 | 03:06 PM
96max3189's Avatar
check the maf plugs that should do it
Old Apr 28, 2009 | 04:33 PM
zzmasta06's Avatar
well my personal mechanic came, he said he put my old MAF on his neighbors 95 gle maxima and it brought up the same problem. My current MAF i just bought from the junkyard did the same as my old. He picked up the junkyard one and its getting another one.. i hope this fixes the problem :\ :\ :\ :\
Old Apr 28, 2009 | 05:12 PM
pmohr's Avatar
No more Maximas...
So you have or have not followed my suggestions above?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
