VQ30DE TO VQ30DE-K swap with no spark
Old Apr 29, 2009 | 09:05 PM
  #41
pmohr's Avatar
No more Maximas...
Originally Posted by carlostelevida
could you call me and i will call you in the morning
1 829 903 5809
sory bro and big thanks
No.
Old Apr 29, 2009 | 09:11 PM
  #42
Product_Of_Korea's Avatar
Originally Posted by pmohr
No.
Old Apr 30, 2009 | 09:51 AM
  #43
carlostelevida's Avatar
after all i thought that there were some bad wiring involve, i put a wire from the positive of the battery direct inside the harness who feed the coils and.
tadaaa.......
yeaaahhhhhhhhhhh uuuyyyyyyyy
the car start, bro this engine is like a charm.
sorry because i though I've made the wiring in the correct way, i felt like a dumb because I've made you both waste your time helping me solve this problems that really didn't exist.
but after all my car is fixed and running, i'm goint to take some days to fine tune it and i will post a video of the car working
http://s684.photobucket.com/albums/v...t=DSC01000.jpg
Old Apr 30, 2009 | 10:07 AM
  #44
pmohr's Avatar
No more Maximas...
tadaaa.......
Wait, that's not even the 00VI...so you swapped in the DE-K and put the USIM on it?
If you don't have power to the coils, then you need to fix that problem correctly, not just hack it up with B+ leads going everywhere.
And are you sure that's even a '96 harness? I see a green push-lock connector on the CPS, those weren't used until what, '99?
Old Apr 30, 2009 | 10:41 AM
  #45
yes
yes, i did solve this, there were a missing wire hangin around inside the harness, exactly the one who feed the coils B+, the boy who solder all the wires, forged to solder this one because he couldnt remember were this wire belongs to, so i was not present when he did solder all the wires, i was at work, but later on i did test all the wires for continuity from the ecu and were all ok, but he didnt say me that little detail, , i want to kill him.
The green push lock conector is a mix because the original conector for the coils were too old and burned, so i decides to swap the olds 96harness conectors with those new one in good in good condition.
http://s684.photobucket.com/albums/vv201/carlostelevida/
Old Apr 30, 2009 | 01:39 PM
  #46
So you pretty much swapped in just a regular de.........
The 00vi will yeild gains of at least 20hp if not more with a good tune. At minimum you could sell it on this site and get at minimum 200 dollars for the whole set so someone else could reek the benifits of the 00vi and you can get some $$$$ back
Old Apr 30, 2009 | 02:15 PM
  #47
jejeje thanks bro, but remember,
im dominican republic it could be too expensive to send it to US, this is not the price everyone wants to afford for a piece that you could get in the place where you live.
but good recomendation, now, the new engine have to pistons that didnt work, the same reason why i decide to swap the old engine ,
tey have spark but just theres no diference if i disconect the plug of the coil number 5 o number 6.
Old Apr 30, 2009 | 02:19 PM
  #48
pmohr's Avatar
No more Maximas...
So have you done any diagnostics on why those two cylinders aren't firing?
So you swapped out an engine rather than completely diagnose two cylinders that wouldn't fire...and after you get the new engine in, again, two cylinders won't fire?
I may be wrong, but I believe they call that 'owned'.
Old Apr 30, 2009 | 03:34 PM
  #49
yes, not the same two cylinders but "owned" at all the old ones failing were by bend valves, caused because a missed tooth, did you remember you helped me to diagnose this.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
